1996 Camry Headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2007, 08:20 PM   #1 (permalink)
Noob
View gladis's Photo Gallery
3rd Generation 1996 Camry Headlights
Hello all, I am new to this forum, I didn't realize there was such a huge and active forum about Toyota Camrys. I have a 1996 Toyota Camry I4 and I'm trying to look for better bulbs for my headlamps. Before doing that, however, I would like to know how exactly I'm supposed to replace the lamps? Also, I'm wondering where the light adjustment screws are, I found the vertical one, which is right next to the side of the car, but can't find the horizontal one. Sorry if these questions are trivial, I've had almost no experience in car maintenance, thanks for all your help in advance!
gladis is offline   Reply With Quote
Old 10-25-2007, 08:33 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
welcome to TN man.
the horizontal adjustment screw is behind the headlight itself.
as far as brighter light, ya dont need to replace the lamp unless its worn. u basically just have to get a brighter bulb, like sylvania silverstar. ur only other option is to do the 9006 to 9005 harness swap to get brighter light or HIDs, both take modifications. u can search for thoes, they have been covered alot.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-25-2007, 08:37 PM   #3 (permalink)
Noob
^^ Thanks I'm having trouble finding the actual way to take the lamp out though, or if replacing the bulb requires me to remove the lamp housing from the car first. And if so, I've been having trouble finding how I'm supposed to go about doing that. Or locating where the bulb is.
Old 10-25-2007, 08:38 PM   #4 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
bigbird said it all, go with OEM SYLVANIA SILVERSTARS unless you want and HID kit, you can also buy the silverstars and get Depo clear off ebay. Hope this helps
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 10-25-2007, 09:18 PM   #5 (permalink)
Noob
What is Depo Clear?
Still, anywhere with specific instructions on how to change a bulb? I have no experience at all
Old 10-25-2007, 09:30 PM   #6 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Instead of having that vertical and horizontal cross-checking on the lense, it is clear, and looks 1,990% better than stock. And as far as removing your headlights... i don't even know how to explain it to you in layman's terms. You just have to reach underneath the front crossmember on the far end of the headlight.
BlueFusion6851 is offline   Reply With Quote
Old 10-25-2007, 09:30 PM   #7 (permalink)
View simplyxtrippin's Photo Gallery
since you're having a hard time removing your headlight, you're probably forgeting to remove a screw. The one i've forgotten before is the one behind the corner light. I'm talking about the one right next to the headlight. I believe that there is a screw holding that light which is above the headlight. Then once you have removed the corner light, you will see a nut (probably gold color).
if you don't want to remove the headlight you might be able to reach the bulbs behind it. It would be behind the body frame, not just behind the headlight. You would see wires sticking out of the headlights.
sorry if i confused you even more.
simplyxtrippin is offline   Reply With Quote
Old 10-25-2007, 09:31 PM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
u cant get depot clears for the 96 (gen3.5 95-96).
sorry i thought u ment replace the lamp. no u dont have to take out the lamp to do so. u reach behind the headlight take hold of the bulb and twist it to the left(clockwise if ur lookin at the headlight) i believe, not real hard. then unclip the bulb harness and put the new bulb on and replace the bulb in the headlight.
R.I.P.
Car Domain:
Old 10-25-2007, 09:41 PM   #9 (permalink)
How hard can it be?
^thank god you're always there to correct me. I should really stop thinking I know as much as i do.
Old 10-25-2007, 10:39 PM   #10 (permalink)
Creeps228's Avatar
i thought they did since everyone was talking about depos b4(talking way back in TN history), sorry for the mixup
MR2: 7A-GE
Old 10-25-2007, 11:49 PM   #11 (permalink)
Noob
No problem, thanks alot, the main thing I wanted to know was if I had to take out the lamp to replace the bulb, since I don't plan on replacing the housing (no yellowing yet, its not as clear as new, but perfectly usable).
So I presume by Clears u mean they use reflector optics instead? (Clear lens seen on most new cars nowadays?)
Should I wish to replace the entire housing in the future, I will ask again!
By the way, is the horizontal adjustment screw white? I see a white screw coming from behind the lamp, still trying to find the bulb.
A final question is whether I have to unplug any electricals before replacing the bulb?
Old 10-26-2007, 04:10 PM   #12 (permalink)
Noob
Follow up question, I found two bulbs on the Kragen website, namely the SU, and ST, The SU is called the Silverstar Ultra, and costs $50, The ST is just called the Silverstar, and costs $20. Can anyone tell me the difference between them?
Old 10-26-2007, 05:14 PM   #13 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
The Ultras are a little bit brighter than the regular silverstars, but not by that much. Just go with the regular silverstars, and save some money.
uibalnme is offline   Reply With Quote
Old 10-26-2007, 05:57 PM   #14 (permalink)
mr.pringles's Avatar
View mr.pringles's Photo Gallery
i believe silverstars are on sale at pepboys with a $15 rebate
92' Camry 5S-FE 179k mi SOLD
96' Camry 1MZ-FE 110k
DDMtuning 4500k HID Kit AutoPage C3-RS665 Remote Start/Alarm Home Depot CAI
mr.pringles is offline   Reply With Quote
Old 10-26-2007, 08:46 PM   #15 (permalink)
Noob
^^ Do they have stores in Northern Califronia?
Toyota Camry Remains America's Best-Selling Passenger Car humanoid Toyota News 0 10-06-2007 03:04 PM
08 Accord EXL-V6 vs Camry SE V6 krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 12 10-01-2007 08:43 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
96 Camry Headlights vn184438 3rd & 4th Generation (1992–1996 & 1997–2001) 7 04-25-2006 11:46 PM
Siphoning gas from 1996 Camry John5788 3rd & 4th Generation (1992–1996 & 1997–2001) 30 12-29-2005 07:12 AM
