It could just be condensation from the air? You live in florida where it is humid to be sure...and in the morning almost all cars anywhere are going to be dripping (clear) water out the tailpipe for several minutes, simply due to moisture inside the exhaust system from overnight.
I dont believe your driving habits are a factor in this problem, a 10 mile drive is plenty of time to warm up the engine and burn out all the moisture, especially in florida.
first find out exactly what is coming out the tailpipe. start the engine and go back to the tailpipe and look at what is coming out. Stick your finger in there and see what you have, If it is water and the water is clear, then count yourself lucky and you can drill a tiny hole (1/8") on the bottom-most part of the muffler to let condensed water drip out instead of building up in there and corroding things.
But if the liquid is the same color as your antifreeze then you have internal coolant leakage, most likely a blown head gasket. If you have been having to add lots of coolant lately - and you didnt mention anything about the coolant level going down - then this is more proof that this is the problem. A blown head gasket is usually fixed by replacing the head gasket (and maybe having a valve job done and replacing the timing belt if the engine has alot of miles and about due).
Before assuming a blown head gasket, though, test it further or have it tested. If you are going to diagnose this yourself you get to play detective now and for that you want to check the following things in no particular order: overheating, spark plugs, compression check, cooling system pressure check, oil color and level.
You didnt mention an overheating problem so i'll assume none. (no overheating is a good sign that maybe the gasket isnt actually blown).
If you do a compression check you are looking for low compression in two adjacent cylinders. If you have high compression in all cylinders, this is great and indicates valves and rings in good shape - but there could still be a blown head gasket anyway (the gasket could just be blown on the outside portion or next to a cooling passage).
So now to check further, you can remove the spark plugs and look at the tips, normal plugs have tan or dark grey/even black tips. If they are rusted or look washed clean or are wet with water, this is another sign of a blown head gasket.
Also you can pressure test the cooling system. to do this you put a cooling system pressure tester over the radiator cap hole/coolant fill cap hole, seal it on there and pump in about 15 psi. A healthy engine will hold 15 psi as long as you want, but if the pressure needle slowly drops, you have a cooling system leak somewhere and probably in the gasket area, given the smoke out the tailpipe.
And also, have you noticed milky colored engine oil or even worse, oil level going UP? this is a sure sign too, of blown head gasket.
But dont assume the worst from all the gloom and doom i have been saying because it may be something minor or even normal - since the condition is intermittent and only happens with engine cold, maybe just retorquing the head bolts would fix it! (If you do try this be sure to retorque them only repeat ONLY with the engine overnight cold. And of course, use the proper tightening sequence too.)
