Severe transmission lag - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2007, 07:33 PM   #1 (permalink)
5S-FU
View Sniperdude's Photo Gallery
Hey guys, I'm getting some real shitty trans lag when my car switches gears. Like it takes like twice as long for gears to kick in, so it feels like I'm redlining before it upshifts and it feels really strange when it downshifts.
What could be causing this?
And would changing out my speed cluster with another one off ebay have caused this problem?
Sniperdude is offline   Reply With Quote
Old 10-27-2007, 11:55 AM   #2 (permalink)
5S-FU
Anyone...?
Old 10-27-2007, 01:20 PM   #3 (permalink)
How does your transmission fluid look? Do you think there could be some sludge accumulated in the trans pan? ... How many miles on your engine/transmission?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 10-27-2007, 03:38 PM   #4 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
if you are worried thats the culprit put the old on back in and try it out... maybe also reset the computer by leaving the battery un hooked for a while and see if that helps, i read somewhere that dang near anything you do has to have the computer reset....
rebel8ball is offline   Reply With Quote
Old 10-30-2007, 09:11 PM   #5 (permalink)
EA6BMECH's Avatar
View EA6BMECH's Photo Gallery
Is the fluid low and or as mentioned above, when was the last time you changed out the fluid? Screen clogged will cause that too. Could be electronics, them some strange animals in shifting timing.
EA6BMECH is offline   Reply With Quote
Old 10-30-2007, 10:48 PM   #6 (permalink)
5S-FU
I should definetly check that. Also, I'll probably reset the ecu tommorow.
The lag is unbelieveable. Also, I noticed the trans doesn't have as much pushing power as it did like 5 weeks ago. It used to like fight it's way uphill if you took the brake off, but now it just struggles.
Old 10-31-2007, 04:21 AM   #7 (permalink)
EA6BMECH's Avatar
Don't mess around on the fluid/filter check. I'd park it until you do it. Those tranny's are expensive!!!!
Old 10-31-2007, 06:40 AM   #8 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
Might consider a code check. There's a procedure involving the O/D lamp and shorting TE1 and E1 on the OBD together. (to the best of my memory)
Dave's is offline   Reply With Quote
Old 10-31-2007, 01:27 PM   #9 (permalink)
5S-FU
You're saying O/D lamp would cause this problem?
What if I just pulled the O/D lamp?
Old 10-31-2007, 01:43 PM   #10 (permalink)
View marc780's Photo Gallery
Are you sure it is not the engine losing power instead of or in addition to the trans problem?
Do a compression check on this engine or better yet a leak down test. I'd make sure the engine is in good order before blaming the trans for being 100% at fault for the poor performance.
If you are sure then that only the trans is at fault, you can try a fluid change or even a flush which might help and possibly even fix the problem.
Other than that, for this type of major transmission problem, unfortunately usually it means the trans needs serious attention meaning it gets rebuilt or replaced. The higher the mileage the more likely this is the fix.
Tranny Oil Xlerator 1st Generation (1995.5–2004) 3 03-19-2007 05:02 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
