ONCE AGAIN, 92 4 cyl not starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2007, 11:09 PM   #1 (permalink)
View Mjakaz95LE's Photo Gallery
3rd Generation ONCE AGAIN, 92 4 cyl not starting
so at the beginning of the month i went thru some bs that turned out to be the ignition coil. Anyhow ever since its gotten colder out, it takes longer to turn it over to start... like 5-10 seconds. Well this morning it was coldest ever and it refused to start period after continuous attempts! so get this.... later this afternoon when it was somewhat warmer, this POS starts up fine and perfect w/no delay!
WHAT IN THE HELL IS THIS?? IIRC i recall hearing something about a coolant temp sensor or whatever causing this? i am getting sick of the petty lil baby problems w/the car. it has had over $1k put into it in the last 2 months!
thank you everyone, i am and have currently been searching for this problem and not having much luck!
Mjakaz95LE is offline   Reply With Quote
Old 10-26-2007, 11:21 PM   #2 (permalink)
View merenjay's Photo Gallery
Have you done a fuel pressure check?
I'm new to Toyotas, and haven't looked at my fuel rail yet, but I assume there is a pressure check service port that you can hook a guage to to make sure the fuel system is pressurizing appropriately. That's where I would look next.
merenjay is offline   Reply With Quote
Old 10-27-2007, 12:27 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
When you are having the problem check to see if the "Check Engine Light" (CEL) comes on when the the ignition key is in the accessory position and the engine is off. It should come on. If it doesn't, the EFI relay is suspect.
My 90 Camry had similar problems. The EFI relay was one factor. A bad ignition switch was my other problem. I had no spark until the car warmed up.
Don't know if this is your problem or not.
Luck,
Kep
Old 10-27-2007, 01:15 AM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
+1 fuel pump may be going out. I had to replace my mom's in her altima because it was doing the same thing.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 10-27-2007, 06:24 AM   #5 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Well it is a 92 after all. Want no problems buy new.
Check your engine coolant temp sensor (not coolant fan switch on rad). If you have a cold start injector check that as well. There is no fuel rail port for pressure check, you'll have to buy a banjo bolt adapter for the fuel filter connection. If this were happening cold or hot I may suspect fuel pump, but not right now.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 10-27-2007, 06:30 AM   #6 (permalink)
Unco's Avatar
View Unco's Photo Gallery
does your camry have a tachometer? when this problem arises, can you see if the tachometer needle goes up slightly as you crank the engine?
if it doesn't, then it's a spark problem.
i just thought i'd throw this in to quickly eliminate a spark problem. i used to have a similar problem in my gen4 celica and it turned out to be a faulty ignitor... drove me nuts for months trying to find the fault.
oh, and try to stay positive. investing money into cars is not a bad thing if you plan to keep it for a long time.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 10-27-2007, 11:31 AM   #7 (permalink)
so where is the cold start injector and coolant temp sensor on the 5sfe? i may just replace both of them. it seems the car starts right up when its 60ish and around 55ish it takes long cranking. Any colder and turns over yet wont start period!
it has to be something to do with a cold start issue. ill just call toyota and see how much the 2 parts are.
Old 10-27-2007, 01:30 PM   #8 (permalink)
Although the Gen 3 online repair manual doesn't have a Diagnostic Section, the Gen 4 Diagnostic Section shows a method of testing the resistance for the coolant temperature sensor .... Probably the same as the Gen 3. You need a multimeter with a resistance test and a thermometer of some sort.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
clear corner for 92 CamryOwner98 Tercel, Paseo, Starlet, and Sera Forum 2 05-23-2008 09:50 PM
92 Celica & 88 4Runner BrightTundra04 Vehicles 0 08-21-2006 08:07 PM
cold starting for '92 scusa 89-95 Toyota Pickup/Hilux 7 11-27-2005 07:05 PM
