Coolant reservoir narrative – FYI
For those with mysterious coolant leaks this might be something to keep in the back of your mind…
Not too long ago I notice my cooling fans running more than I remember them running. Car was not overheating so I didn’t take much notice. Then, I noticed tiny drips of coolant on my garage floor. Now I was worried. With pretty extensive searching, hoses, clamps, etc., I finally traced the leak back to a crack in the coolant reservoir where the reservoir mounts to the inside of the front quarter panel. From sloshing about the coolant inside the reservoir would occasionally leak out and drip down. In addition, this crack in the reservoir must have caused a tiny pressure loss in the cooling system, apparently enough to cause the engine to run slightly hotter, since the fans were running more frequently, because, now, they’re running much less. I've since learned these reservoirs are prone to crack in this location.
Always wanting to contribute my ‘mysteries solved’ stories in case it might assist someone else out there.
BTW – Vehicle is a 96 V6 Camry
Over and out.
