Radio noise with window heater - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2007, 10:55 AM   #1 (permalink)
View mathu.bala's Photo Gallery
Hi,
I've recently purchased a 2000 Camry LE. I did a CD Player + Rear speaker installation. My problem is when I turn on the window heater, my radio signal drops. I have so much noise coming out of speaker that I can't even listen to it for second. I assume the antenna is somewhere in the back where I did the speaker installation. Does anyone know how the antenna looks like and where exactly is it? Thanks.
mathu.bala is offline   Reply With Quote
Old 10-28-2007, 11:28 AM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Can you be more specific about the noise. Im assuming that the cd player and rear speakers are aftermarket... Check your grounds...
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 10-28-2007, 11:32 AM   #3 (permalink)
The Connoisseur
CharmCityES's Avatar
are u getting static and interference?
because the antenna is integrated into the rear window, and the defroster interferes with it. happens all the time on my 03 SE
The "Executive Sedan"
Old 10-28-2007, 12:54 PM   #4 (permalink)
Did you have heater radio interference prior to installation of new CD/Spkrs?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 10-28-2007, 01:30 PM   #5 (permalink)
Hi thank you all for replying...
Yes it's an aftermarket audio system. I did not have any static before the installation. Even after installation, the radio is crystal clear but once I turn on the defrost, I can only hear anything but *hiss*. If I turn the defrost off then the radio goes back to normal.
Old 10-28-2007, 03:23 PM   #6 (permalink)
If you have the radio antenna wire (black with red stripe) close to the
Defogger wire (solid black) ... you might get interference.
Do you have the printed glass antenna on the rear window? ...or a motor operated antenna?
If you disconnect one of the rear speakers at a time ... both wires ... do you still get the noise interference?
TCH w/ Nav Radio Noise pdicristina Camry Hybrid 6 05-22-2007 12:46 PM
Satellite radio noise from the Aux port.. 07 Camry dirtdiggler 5th & 6th Generation (2002-2006 & 2007-2011) 2 11-29-2006 09:30 PM
Help...excessive road noise islandx Tercel, Paseo, Starlet, and Sera Forum 5 02-01-2006 05:08 AM
window noise 20camry00 Camry & Solara Lounge 2 03-22-2005 11:00 AM
Heater fan making noise daisy turtle General Discussion 0 11-14-2004 01:06 AM
