V6 HG Problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2007, 11:40 AM   #1 (permalink)
View cwc418's Photo Gallery
V6 HG Problems
Ok, I am 99% sure I have a blown HG in my 1993 XLE V6. The car has 276K. Is it better to have this engine rebuilt or get a replacement engine? Is this engine easy to rebuild? What are pros and cons of both? I would also like to know what this is going to cost.
cwc418 is offline   Reply With Quote
Old 10-28-2007, 06:09 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
depending on where u get it a used engine would be cheaper. if u were gonna do a rebuild then id suggest doing a full rebuild with rings, seals, new valve train components, ect. labor on a rebuild is what will kill ya and thats where replaceing the engine might be cheaper as well.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 10-28-2007, 10:17 PM   #3 (permalink)
TheKevin's Avatar
iTrader Score: 6 reviews
View TheKevin's Photo Gallery
I'm in the same boat as you. The oil in the motor is milky already. It doesnt even crank anymore. I spoke to a mechanic at a reputable shop and he suggested that I replace the motor. He said he could just rebuild the curent motor but eventually it will cost the same as replacing and it'll be prone to a BHG again.
TheKevin is offline   Reply With Quote
Old 10-28-2007, 10:28 PM   #4 (permalink)
View 93CamryLEV6's Photo Gallery
Yeah, I would just recommend getting the original repaired... like he said, the next engine could be soon in line for the same problem, unless you know it has had the gaskets replaced.
93CamryLEV6 is offline   Reply With Quote
Old 10-28-2007, 11:14 PM   #5 (permalink)
Mr. E,
Are you suggesting that if your mechanic rebuilds your engine it will be prone to BHG...or a replacement engine will be prone to a BHG? What did your mechanic quote you on a rebuild? Does anyone know specific costs?
Old 10-28-2007, 11:39 PM   #6 (permalink)
View mcelligott's Photo Gallery
If your heads are not warped, just replace the head gaskets.
Turbo 3vz-fe with Nitrous...you have questions? I have answers, Get a hold of me on aim!
mcelligott is offline   Reply With Quote
Old 10-30-2007, 06:47 PM   #7 (permalink)
TheKevin's Avatar
Originally Posted by cwc418 View Post
Mr. E,
in my situation, my mechanic recommended that the replacement engine would be better. rebuilding the current one would be a money pit.
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 02:49 PM
so i crunched some numbers, true carlo$ 5th & 6th Generation (2002-2006 & 2007-2011) 36 10-28-2007 06:12 AM
2002 3.4L V6 Engine Problems masterstompy 1st Generation (1995.5–2004) 3 02-18-2006 06:41 PM
Starting Problems with Camry 1990 LE V6 njsp_1 1st & 2nd Generation (1983–1986 & 1987-1991) 7 01-24-2005 10:30 PM
Camry V6 Manual problems? shimkc Camry & Solara Lounge 2 09-17-2003 04:18 PM
