1999 camry problems with fan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2007, 03:56 PM   #1 (permalink)
View daveofstrength's Photo Gallery
Question 1999 camry problems with fan
the fan only seems to operate when it is on the third or fourth setting(highest)
doesnt work when its on setting 1 or 2(low)
what might be the problem here? how can i fix this without facing $$$$ at a shop?
daveofstrength is offline   Reply With Quote
Old 10-30-2007, 10:06 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Do a search for posts on fan resistors. I'm not familiar with how the 1999's is configured. However, when they wear out the fan looses the low speeds first and finally it defaults to hi speed. The 1990s can be replaced or even repaired, I expect that the 1999s are similar. It shouldn't hurt anything if you only use the higher speeds.
Kep
Old 07-08-2008, 04:45 PM   #3 (permalink)
View Jer in Ottawa's Photo Gallery
Hey Daveofstrength.
Do you have a follow up as to what the problem was? This same problem just happend to mine last night. Only HI speed works, no more 1, 2, 3.
Thanks.
Jer.
Jer in Ottawa is offline   Reply With Quote
Old 07-08-2008, 05:31 PM   #4 (permalink)
nope, im still without the lower power settings...
Old 07-09-2008, 04:34 PM   #5 (permalink)
Gameroom cash: $303055
You both have the classic symptoms of a bad blower motor resistor. Do a search. This has been covered numerous times. It's very easy to replace.
Mike
Old 07-10-2008, 01:29 AM   #6 (permalink)
View FrankXT86's Photo Gallery
2000 camry blower motor resistor
View that thread, same as the 1999... definitely the blower motor resistor, just replaced mine, quick and easy fix.
1999 Toyota Camry LE
2.2L I4 (5S-FE)
Mobil-1 5w-30 Synthetic
130K+ Miles
BF-Goodrich Revelation Tires
FrankXT86 is offline   Reply With Quote
08 Accord EXL-V6 vs Camry SE krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 17 05-22-2009 10:12 PM
08 Accord EXL-V6 vs Camry SE V6 krispykreme 5th & 6th Generation (2002-2006 & 2007-2011) 12 10-01-2007 08:43 PM
91 Camry Fan problems bigbikes2003 1st & 2nd Generation (1983–1986 & 1987-1991) 8 03-20-2007 04:02 PM
1999 Camry, should I upgrade? geoff5093 3rd & 4th Generation (1992–1996 & 1997–2001) 7 01-12-2007 12:09 PM
Which stock CD/tape players fit 1999 Camry LE? jbrams 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-11-2007 08:09 PM
