Rear speaker mounting bolts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2007, 10:48 AM   #1 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I currently have after market 6x9 speakers in my rear deck and have just gotten mounting adapters from ebay to mount them properly, but I no long seem to have the original bolts that mounted the stock speakers to the rear deck and I need them. Does anyone know the bolt size (as far as threads) for these so that I can buy them? Thanks.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 11-01-2007, 12:31 PM   #2 (permalink)
TRDSleeper's Avatar
View TRDSleeper's Photo Gallery
The best thing to do is go to your local Toyota dealership and special order the bolts if you want exact fitment. It'll be exactly as the original but will cost more than the typical bolts you can get at the hardware store. It shouldn't be more than a dollar-something each. I still have the bolts for my rear 6x9 speakers but I don't know how to determine the thread.
TRDSleeper is offline   Reply With Quote
Old 11-01-2007, 12:56 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
That wouldnt be the 'best' thing to do.
Take the bolt to home depot or lowes. They have a little board mounted in the bolt section so that you can screw your bolt into to find the thread size. Once you know the size...get the length you need. Cheap, easy, fast.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-01-2007, 02:33 PM   #4 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
I think the 2 mounting bolts for the third brake light are the same thread pattern. Since you don't have the original speaker bolts anymore, try removing one of the bolts for the third break light, and take that one to home depot to match it.
uibalnme is offline   Reply With Quote
Old 11-01-2007, 02:51 PM   #5 (permalink)
'95 Camry 5S-FE
^ thanks, I'll have to do that then.
Old 11-01-2007, 03:34 PM   #6 (permalink)
My bad...for some reason I read that the original bolts werent long enough...not that you no longer had them.
My apologies.
Id check to see if they are the same thread pattern as the third brake light before going through all that trouble. But if they are...thats great.
Old 11-01-2007, 05:43 PM   #7 (permalink)
'95 Camry 5S-FE
Thanks for everyones help. I was about to test the brake light bolt, but then found a single bolt in my toolbox that fit, so I used that to size them up. Turns out they are 6mm x 1.0
93-97 Rear speaker bracket Sandman614 7th Generation (1993-1997) 0 10-29-2007 10:24 AM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
07 rear speaker removable. info needed. dirtdiggler 5th & 6th Generation (2002-2006 & 2007-2011) 6 01-15-2007 08:32 PM
No rear speakers?!?!!?!!! cam2Xrunner Audio, Video, and Security - Tech 83 06-15-2006 12:19 PM
1992 Camry CSI LTD Rear speaker removal Protaeus 3rd & 4th Generation (1992–1996 & 1997–2001) 4 02-18-2006 09:56 PM
