1993 Camry 5DR Wagon, need HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2007, 10:44 PM   #1 (permalink)
View kahi's Photo Gallery
My transmission was giving me a little bit of trouble so I changed the filter and everything was fine.
Now (about 2 months and 800 miles later) it is giving me trouble again. Here is what's going on.
The car engages in gear, but the RPMs are not going up, acting like its not accelerating, and it feels like its accelerating heavy if that makes since.
5 minutes after driving it disengages gear as it will not go anywhere until I put the car in park, turn it off, turn it back on, and engage in gear again.
What do you think is going on? any help would be VERY appreciated. I am a poor college student paying his own tuition so my funds are very limited.
kahi is offline   Reply With Quote
Old 11-03-2007, 10:54 PM   #2 (permalink)
View ihartmacz's Photo Gallery
Check the fluid level again.
Check for shorts or unhooked wired underneath the car by the tranny, thats almost all i could say.
ihartmacz is offline   Reply With Quote
Old 11-03-2007, 10:57 PM   #3 (permalink)
Loss of cylinder compression in the engine? Can you do a compression check on the cylinders?
How many miles on it?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-03-2007, 11:13 PM   #4 (permalink)
I will check all of that
and 122,000 miles are on it
any other suggestions?
Old 11-03-2007, 11:14 PM   #5 (permalink)
Not really high miles for compression loss .... probably something else.
.... Unless there is some other symptom .... like headgasket problems.
Old 11-03-2007, 11:19 PM   #6 (permalink)
well the car is not staying in gear
Old 11-03-2007, 11:24 PM   #7 (permalink)
Head problems aren't going to affect the way the trans. shifts.
It might be a solenoid or something. Check for broken/shorted wires, clean connectors going to trans computer, check vacuum lines, check the fluid level.
Add some transtune.
How do you drive the car? drive it hard?
Old 11-04-2007, 09:14 AM   #8 (permalink)
The only time that I recall something like this .... driving for a while and then stopping, was when an oil pickup screen in the bottom of the oil pan became clogged with plastic pieces .... resulting from a loose electrical connector being shredded by the crankshaft.
At any rate, maybe something is clogging the filter screen of your transmission pan. After you stop driving, the debris falls to the bottom, until you start driving again and the pump suction draws the sludge or whatever up into the screen.
If it is not your transmission pan and pump, maybe it is in your oil pan. Transmission pan would probably be easiest to check though.
No, this scenario is not very likely .... but it seems to fit the problem description which you have provided so far.
Old 11-04-2007, 01:49 PM   #9 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
OP,
Check the linkage adjustment.
DFBonnett is offline   Reply With Quote
Old 11-04-2007, 03:22 PM   #10 (permalink)
The Flying Kiwi
papariccardo's Avatar
View papariccardo's Photo Gallery
The only time that I recall something like this .... driving for a while and then stopping, was when an oil pickup screen in the bottom of the oil pan became clogged with plastic pieces .... After you stop driving, the debris falls to the bottom, until you start driving again and the pump suction draws the sludge or whatever up into the screen. No, this scenario is not very likely .... but it seems to fit the problem description which you have provided so far.
Aren't forums great! Good answer, cam. Makes sense.
I was gonna suggest resetting the ECU by disconnecting the negative terminal for a few minutes, but rereading seems you may have stumbled on to the answer.
3.0G Gen 3 wagon, TCS 7str (JDM), Nissan Z32 Twin Turbo 2+2 5sp Targa (JDM)
papariccardo is offline   Reply With Quote
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
INFO: 1996 Toyota Camry Specifications Ratko 3rd & 4th Generation (1992–1996 & 1997–2001) 22 08-08-2009 05:09 PM
Looking to buy a 1993 Camry LE goog1986 3rd & 4th Generation (1992–1996 & 1997–2001) 13 10-02-2007 06:11 PM
88 Camry wagon all trac conversion Jimbologist 1st & 2nd Generation (1983–1986 & 1987-1991) 4 04-07-2005 09:49 AM
Radiator replacement... '93 Camry V6 Wagon xxg00chxx 3rd & 4th Generation (1992–1996 & 1997–2001) 3 03-04-2005 07:28 AM
