Engine mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2007, 04:26 PM   #1 (permalink)
TN User
View argh's Photo Gallery
3rd Generation Engine mounts
For those with 10+ year old gen 3 Camrys, has anyone went ahead and replaced all the mounts even though only one had been found to be bad? If so, how much did that end up costing?
argh is offline   Reply With Quote
Old 11-04-2007, 04:31 PM   #2 (permalink)
Supraman
View 94_Toyo_Cam's Photo Gallery
i have, it ends up costing a few hundred bucks. If you do replace em, get oem toyota mounts, they work a lot better. You could also do the job yourself to save some $$. I replaced mine because the front mount was broken and ended up breaking the rear one, and once I replaced that the front went again.
94_Toyo_Cam is offline   Reply With Quote
Old 11-04-2007, 10:15 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
$384.50 for OEM mounts from www.toyotadiscountparts.com That's INSANE!
Id never spend that much on mounts!
$150 shipped on ebay for Lifetime Warranty mounts.
http://cgi.ebay.com/ebaymotors/CAMRY-92-93-94-95-96-ENGINE-TRANSMISSION-ENGINE-MOUNT_W0QQcmdZViewItemQQcategoryZ50454QQihZ009QQit emZ190168517719QQrdZ1QQsspagenameZWDVW
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-04-2007, 11:20 PM   #4 (permalink)
TN User
What about polyurethane mounts? Is the purported increase in vibrations that significant?
Old 11-04-2007, 11:20 PM   #5 (permalink)
View J708's Photo Gallery
I just replaced mine on the weekend for the first time after 12 years. ofcourse only been driven for 112k miles. Can't really help you with cost, cause I replaced a bunch of other things
Camry 1996 2.2L - 121,000+ miles
J708 is offline   Reply With Quote
Old 11-05-2007, 07:34 AM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
why would you want polyurethane engine mounts?? i can understand polyurethane suspension bushings to limit flex, but why would you want to do this for the engine? the only thing i can see with this is the car will vibrate more from the motor. performance and handling wont change.
Old 11-05-2007, 12:30 PM   #7 (permalink)
TN User
They are much stiffer than rubber and therefore hold the drivetrain in place much better? And they last longer?
My other consideration would be OEM mounts, but they are quite pricey..
Old 11-05-2007, 12:36 PM   #8 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
I have a polyurethane dog bone motor mount and love it. It definitely helps with initial acceleration. It was a pain to install because I could only get the inserts, so I have to press out the old rubber bushings and press in the polyurethane ones. I think I paid $40 for the inserts.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 11-05-2007, 01:19 PM   #9 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
IMO, go OEM all the way. Sure, the aftermarket ones have a lifetime warentee, but how uch labor do you wanna do to replace them, again.
5 Lug Corolla WHAT?
Old 11-05-2007, 02:12 PM   #10 (permalink)
Pissed
View Camryamnesty's Photo Gallery
I bought mounts on ebay for about 50 bux for ALL. It was a steal so i bought em. Look around ebay you may find something.
Camryamnesty is offline   Reply With Quote
Old 11-05-2007, 08:44 PM   #11 (permalink)
Newbie
View 94cylcamry's Photo Gallery
I was wondering this as well...the vibration when sitting at stop lights and signs and what not is getting pretty bad. Mine is a 94 Camry LE with 150k miles on her. And curious, how many motor mounts does this thing have? I think I'll go ahead and replace them all while I'm at it, but I'm confused as to whether there are 3 or 4.
Thanks.
94cylcamry is offline   Reply With Quote
Old 11-05-2007, 09:26 PM   #12 (permalink)
'95 Camry 5S-FE
^ there are 4 mounts. 1 dog bone (top passenger side), 1 front mount(by the radiator), 1 rear mount(by the firewall), and 1 tranny mount(on top of the tranny).
Old 11-05-2007, 09:30 PM   #13 (permalink)
My mounts have never been replaced. The only one that looks a little worn is the dogbone. Ill prolly replace them all eventually though...but NOT with OEM mounts. Cannot justify the price.
Old 11-06-2007, 12:32 AM   #14 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
if you have an automatic and you're pushing stock power, then ebay mounts will do the job
but if you're 5-speed and you like to push your car (or put down some power- i.e. blown v6, etc.) then you want oem mounts and the price IS justifiable...
I went cheap and picked up an ebay set of motor mounts for my 5-speed swap and even though they worked, they sucked. The engine would move like mad under launch and hard acceleration. It made it hard for a 300bhp car to spin its tires!!! You could literally feel the entire engine rocking.
I just got another tranny mount- a used oem one, and the difference is night and day. Even by placing them side by side, the quality and even the size of the rubber used is different.
If money is an issue though, the ebay ones will get you through until you can find some cheap oem ones
HaHa
Old 11-19-2007, 01:07 AM   #15 (permalink)
TN User
Where can the cheapest pricing for OEM mounts be found? Or if there are any go-to sites anyone frequents for parts that would be helpful.
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
"A" engine info freakinbox Archived Corolla threads 29 05-10-2006 12:05 AM
engine mounts tightcamry129 Camry & Solara Lounge 0 07-22-2004 10:31 PM
Is Engine Cradles = Engine Mounts? Protocold Archived Corolla threads 2 03-16-2004 06:13 PM
