Can someone tell me where to put this transmission treatment? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2007, 06:30 PM   #1 (permalink)
Camryv6xle's Avatar
View Camryv6xle's Photo Gallery
3rd Generation Can someone tell me where to put this transmission treatment?
i just bought some transmedic, and i dont know where to put it lol. Can anyone show me or tell me where to put it? i have a 1994 camry v6 thank you
Camryv6xle is offline   Reply With Quote
Old 11-04-2007, 06:42 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
What's wrong with the transmission and what does that stuff do?
What do the instructions say?
If you want to mix it with the transmission fluid, you just pour it in the dipstick tube for the transmission fluid. You fill the ATF the same way if you haven't done so before.
When you open your hood, you should see two dipsticks. The left one is for engine oil. The right one is for the transmission.
The above is assuming you have an automatic. If you have a manual transmission, you need to get under the car, find the fill plug and remove it, then pour the stuff in.
2007 Camry 2.4L 5M
Old 11-04-2007, 06:50 PM   #3 (permalink)
Camryv6xle's Avatar
Arrow
thanks for the help dude, I was thinking about the dipstick tube but was like nah. well its solder eal GUNK TRANSMEDIC. eliminates slippage, smoothes shifting and reduces engine wear and noise. Directions say to add it to the transmission fluid, thats all.
Old 11-05-2007, 06:22 PM   #4 (permalink)
View wahed3001's Photo Gallery
Are sure you want that thing in your transmission? Is there anything wrong with the transmission?
wahed3001 is offline   Reply With Quote
Old 11-05-2007, 07:03 PM   #5 (permalink)
Camryv6xle's Avatar
well it does shift slightly roughly, however ive driven it today after putting it in and im getting some better response from it, hopefull with a couple more miles ill see a little bit more, im not expecting much however, do expect something
http://i89.photobucket.com/albums/k205/gunit2049/0108091104-00-1.jpg
Old 11-05-2007, 08:18 PM   #6 (permalink)
Camryv6xle's Avatar
Old 11-05-2007, 09:20 PM   #7 (permalink)
When was the last time you changed the transmission fluid? Automatics shift rougher as the fluid ages. Dexron III fluid is supposed to be change approx every 30000 miles or so.
2007 Camry 2.4L 5M
Old 11-05-2007, 09:23 PM   #8 (permalink)
Camryv6xle's Avatar
transmission fluid was probably changed 3 years ago
Old 11-05-2007, 09:46 PM   #9 (permalink)
You should try changing the fluid to see if that helps any. That could be the cause of the rough shifts and that stuff you're using would be a band aid solution that could make things worse.
If you need help to do it, there have been a lot of posts on this forum with guides, hints, and instructions.
2007 Camry 2.4L 5M
Old 11-05-2007, 09:47 PM   #10 (permalink)
Camryv6xle's Avatar
hmmm, i gotta look into that.
Old 11-06-2007, 03:39 PM   #11 (permalink)
Just do a few drains a refills. I use Valvoline dex III in my tranny.
DIY flush transmission fluid popeye08 Camry & Solara Lounge 6 07-02-2010 11:10 AM
HELP: Serious Transmission Problems arcasmachineracing Camry & Solara Lounge 23 06-22-2008 11:53 PM
HELP!!! Weird/Strange Sound from Transmission after ATF Change junkyudog 5th & 6th Generation (2002-2006 & 2007-2011) 31 10-12-2007 09:09 PM
Anyone ever venture to the truck forums once in a while? CamNub General Discussion 67 09-15-2007 10:12 PM
Mister Transmission in Markham Im_a_dickhead Feedback: Buyers, Sellers, and Vendors 4 07-31-2002 09:43 PM
