Brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2007, 07:00 PM   #1 (permalink)
Rubbish.
jsl222's Avatar
View jsl222's Photo Gallery
Brakes
It's been way overdue for me to change my rear drums. They sound horrible and even worse when wet. I was wondering how much each drum went for. $100? $150? I've been thinking about doing a rear drum to disk conversion. Would this be easy? Has anyone done it before on the 3rd gen or anything similar? If so, how much did you spend? Oh and also, what are the stock light bulbs on the 3rd gen: 9005 or 9006..I'm referring to the regular beams(low) Thank You
jsl222 is offline   Reply With Quote
Old 11-04-2007, 07:03 PM   #2 (permalink)
View camryfreak09's Photo Gallery
i think u should buy a full set of brembos and keep ur stock pads the all four willl run around 400, but if u just want stock just go to autozone should be aroung 100, the 3 gens have 9006 as light bulbs
camryfreak09 is offline   Reply With Quote
Old 11-04-2007, 07:29 PM   #3 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
You could do a rear brake conversion on a gen 4 camry pretty easily but im not sure about a gen 3 camry. However, there are a few people who have done conversions here on the forum. Search around and you'll find them, i believe the member called tony the tiger did it.
camry man68 is offline   Reply With Quote
Old 11-04-2007, 07:58 PM   #4 (permalink)
Rubbish.
jsl222's Avatar
Thanks for the replies. I've been wanting to do the conversion for a while now cause the rear drums feel kind of weak.
Old 11-04-2007, 08:05 PM   #5 (permalink)
Import Tuning
I know on gen 4 camrys, it could work for gen 3's, you take the rear brakes from v6 camry or the lexus es300 and you can put them on your camry. You need the discs, calipers, lines, brake booster, and the brake cylinder/valve control thing. I forget exactly what its called. But, it controls how much pressure is sent to each brake disc or drum. Then its a simple bolt on installation that involves draining the brake fluids.
Old 11-04-2007, 08:40 PM   #6 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $445645
View uibalnme's Photo Gallery
Proportioning valve.
uibalnme is offline   Reply With Quote
Old 11-05-2007, 02:43 PM   #7 (permalink)
Gameroom cash: $303055
Use this link for any future questions about light bulbs for your car:
http://www.sylvania.com/ConsumerProd...de/default.htm
Mike
Old 11-05-2007, 04:59 PM   #8 (permalink)
Rubbish.
jsl222's Avatar
Mike
thanks for the site man
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
1995 Camry LE Soft Brakes kentarver 3rd & 4th Generation (1992–1996 & 1997–2001) 14 10-17-2006 06:33 AM
Brakes, How are yours? Chazmanian 2nd Generation (2005+) 45 03-24-2006 03:18 AM
Changing Drum Brakes to Disk Brakes on 2003 LE DragonR6 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-10-2004 04:07 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 10:38 PM
