Headlights help... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2007, 08:38 PM   #1 (permalink)
Noob
View gladis's Photo Gallery
Headlights help...
Hey all... I'm so depressed right now
I tried to polish out my headlights as 11 years of wear and tear have caused some significant dings.
So I tried the sanding + PlastX method.
Since there were some big dings, I started with 320 grit sandpaper and worked down the grits to 2000. I wetsanded.
Then I finished with some PlastX. But... now there are fine scratches all over my lamp (whereas there were only some and some dings before)!!!
Anyone have an idea how I can remedy it? It took about an hour to do each lamp, maybe I didn't work on it for long enough?
I'm thinking some clearcoat or getting a powerball or some rubbing compound, but I'm already broke...
Anyway, thanks for any help, guys...
gladis is offline   Reply With Quote
Old 11-04-2007, 08:50 PM   #2 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
wow you used 320? or 3200? i went from 1000 and worked my way up to 2000. and did the polish and then plastx. accept i just gotta use plastx everyone once in a while. but try to get some polish.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 11-04-2007, 08:53 PM   #3 (permalink)
Noob
320. I suppose I should say UP. There were some chips that were fairly deep, so I tried using a rougher paper to sand through it. I got it to be smooth, but the dings were still there.
Anyhow, i went to 2000, and PlastX'ed.
I'll post a picture if I can.
I'm thinking maybe I was lazy and didn't spend enough time. I'm thinking of redoing it, but I dont want to waste another hour. If I redoing it, should I start at a higher grit?
edit: here's the picture
Old 11-04-2007, 09:29 PM   #4 (permalink)
The Flying Kiwi
papariccardo's Avatar
View papariccardo's Photo Gallery
Bugger. The 320 did that, hope no TN member suggested it. 1200 minimum, finish with 2000. Myself, I NEVER sandpaper, easier ways like this next option. I would probably now borrow a high speed small orbital polisher (or sweet talk some boy at the valet) and do it with brasso or any good metal polish. These are very fine cutting compounds - Silver polish also works great. 3-10 minutes each light with the right machine should sort it. Use caution on the surrounding trim.
Or lots more sanding with the 1000-2000, may be the only way now to deal with it. But I still don't like sandpaper.
Whatever way you do, finish with a quality auto wax, as the surface will be totally unprotected. Best of luck Gladis.
3.0G Gen 3 wagon, TCS 7str (JDM), Nissan Z32 Twin Turbo 2+2 5sp Targa (JDM)
papariccardo is offline   Reply With Quote
Old 11-04-2007, 09:31 PM   #5 (permalink)
Noob
dont have handy friends handy, much less car savvy friends.
All rich snobs who take their cars to shops in my quiet suburb, lol.
Gonna have to do with the manual option and see what happen.
Won't going with 1000 be marginally easier, get through it quicker? Or even 800? I guess I'll get a sanding pad to keep my hands from falling off
Old 11-04-2007, 09:39 PM   #6 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
the lower the grit the deeper you will gouge out the surface, which is why you have the scrathes, now you have to take off all the material around the scrathces to get them smooth again, if you were doing paint an body your primer or some putty would fill them, since you are not going to cover the headlights with anything, your only option is to keep polishing till its smoothed out, yes it will take a long time, but if you start with a lower grit you will make even more work for yourself. also i would wet sand with a sanding sponge to keep from getting finger valleys. also check with some parts houses, they might have polishers you can rent.
rebel8ball is offline   Reply With Quote
Old 11-04-2007, 09:42 PM   #7 (permalink)
Noob
I'll find a sanding sponge, what's a parts house?
For now I gotta worry about my chem midterm and take my mind off of it for a while...
What a mistake! :/
Old 11-04-2007, 09:42 PM   #8 (permalink)
The Flying Kiwi
1000, on a sanding block, or proper pad. I don't recommend less grit than that. Finish with a 1500 & 2000. Wet, use a bucket, easier than the hose. Glove up. You've probably lost all your fingerprints now - good time to deal to that ex!
And don't beat yourself up over it - noone else but you will notice it, it's hardly that much of a biggie. A parts house is an auto supply store. The car valet guys may do it for you for $20 - try them.
Old 11-04-2007, 09:45 PM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
welp the only way to get rid of them is keep sanding with real fine sandpaper till they are gone or just get new headlights.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-04-2007, 09:50 PM   #10 (permalink)
Noob
Yea, I'm not shelling out 200 bucks for new headlights. I guess I'll work on them during my free time.
Old 11-04-2007, 09:51 PM   #11 (permalink)
Noob
Thanks, if I can't get these out in a couple days' work I'll go find some help.
Is car valet a shop?
Old 11-04-2007, 10:01 PM   #12 (permalink)
The Flying Kiwi
A place that grooms/ cleans/ details (call it what you will) cars for clients. May be listed as Car Groomers in your local phone directory. Best of luck.
Old 11-04-2007, 10:02 PM   #13 (permalink)
Noob
Ahh, no wonder, I was thinking about parking valets, wondering why parking ppl would have a buffer on hand,
Old 11-04-2007, 10:07 PM   #14 (permalink)
xet
View xet's Photo Gallery
hahaha
make sure u get the sanding block and wet sand properly and dont go too hard and unevenly this time
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 11-04-2007, 10:21 PM   #15 (permalink)
masteryota1's Avatar
View masteryota1's Photo Gallery
thats what i was thinking until i saw the guys location said NEW ZEALAND.
masteryota1 is offline   Reply With Quote
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
93 Headlights simms 89-95 Toyota Pickup/Hilux 3 07-03-2006 11:14 PM
Clear Headlights.......Come look! luisitol Camry & Solara Lounge 34 07-02-2005 08:47 AM
