Did I do any damage to my tranny?
This is going to make me look like a moron, but I cracked my head on my camry by running it with no oil. I had been having oil leaks, so I replaced the crankshaft and oil pump seals and the oil pan and valve cover gaskets. She didnt leak nowhere near as much as she was but I still noticed drops in the driveway. My wife was comming home and she said the oil wrng lite flickerd a few times so I told if it came on steady pull off and get some oil. She got home and I jumped in the car, forgetting all about the oil lite and drove across town. Man that thing started knocking and burning. As I put oil in it, it was running out of the bottom, a small stream. I tried to make it home, but the tranny started slipping. First at 60mph, I'd back off the gas then the speed at which it would slip just kept getting lower. I pulled over and shut it off. I have another engine, but do you guys think the trannys gone too. Its an A/T, so I don't want to drop in a new eng to find after all that work the trans is bad. Any thoughts?
 I fly high, no lie
