No heat on the feet. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2007, 02:03 PM   #1 (permalink)
View David1990's Photo Gallery
3rd Generation No heat on the feet.
I have a 94 LE, and the heat comes out fine at the dash, but when you turn the knob to put the heat on the floor no heat comes out on the drivers or passengers side. What could it be?
1994 Camry LE I4 Leather, sunroof, Alpine CDA-9856 head unit, Alpine Type S Speakers, Alpine 450W amp, and 2 12" Alpine Type E Subs
2007 Camry XLE V6 Magnetic Grey/Bisque, Navigation, Smart Key, and 20% tint
David1990 is offline   Reply With Quote
Old 11-06-2007, 03:03 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
It sounds like your A/C control assembly (climate control) is on the fritz, if you know where your A connector is and have something to test continuity with (DVOM, test light, etc) bridge A10 and A1, if you don't have continuity, the climate control is shot.
BlueFusion6851 is offline   Reply With Quote
Old 11-06-2007, 04:41 PM   #3 (permalink)
5S-FU
View Sniperdude's Photo Gallery
It could also be that your vent isn't open down there.
Take a look beneath the steering column and the vent should be open and blowing. Otherwise your air vent changing motor is blown, most likely.
Sniperdude is offline   Reply With Quote
Old 11-06-2007, 05:43 PM   #4 (permalink)
Also, the heat comes out from the dashboard vents.
Old 11-06-2007, 11:11 PM   #5 (permalink)
How hard can it be?
^Instead of the feet?
Old 11-07-2007, 12:04 AM   #6 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The fan box has one or more blender doors in it that move around to direct the air flow (either hear or AC, it doesn't matter). The door(s) can get stuck with crud or the blender motor can fail, a linkage can break or the switch can fail. If you have the push button type selectors for vent/floor/face/def then you will have the switch and motor to check. If you have the slide lever then you will have a cable connecting directly to the blend door lever. The manual goes into this in the Body Electric section (BE 52 for the 1990 model).
Kep
2005 Highlander "Foot" Heat Not Working ChristineVA 1st Generation (2001–2007) 2 10-29-2007 10:32 AM
93 22re gets hot when heat turned on FeelTheMist 89-95 Toyota Pickup/Hilux 2 08-22-2007 10:42 PM
Consumer Reports tests 1/2 and 3/4-ton pickups: Silverado, Ram, F-Series, Tundra IFCAR General Discussion 8 07-31-2007 05:22 PM
1988 Camry Heater Cycles Between Heat & No Heat lashby 1st & 2nd Generation (1983–1986 & 1987-1991) 30 12-11-2006 03:29 PM
its cold, how's your heat? mazdaverx7 3rd & 4th Generation (1992–1996 & 1997–2001) 16 10-26-2006 07:34 AM
