Simple Questions...Need Answers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2007, 09:51 PM   #1 (permalink)
Creeps228's Avatar
Gameroom cash: $286818
iTrader Score: 6 reviews
View Creeps228's Photo Gallery
I have some questions i'll like to ask. I need to know your knowledge, opinions, suggestions, and please dont leave me with my head in the clouds, its been several times that I make a thread and get some answers and then i'll ask one more question and then have my head in the clouds wondering about my question. Anyways back to the thread topic...
Saturday, my foglights were working, but i turned them off since there was no need for them, but one was off, but it normally does that ( a few taps to the lens and it turns on ). Once I got home i decided to turn them back on, to fix the mesedup one, but neither of them turned on. So im thinkking maybe the fuse is gone, but it wasnt becasue i tapped the foglights to the whiperblade FUSE and the wipers are still working till this day. Im thinking the bulbs burned out. But now i dont know what to do?
1)Should i get new foglights: IF so which ones OR
2)Should i get new bulbs?
Im looking to "upgrade" the electrical stuff with the car, I'm going to be buying a ground kit, and I was looking for the spark plug wires for my car but i dont know which ones are the good ones. So my question to you is which one(s) are the best spark plug wires to buy, i tried looking at the sticky thread about the camry FAQs but there was nothing there on spark plug wire.
I also have some more question but they arent coming to me atm, so please give me some advice
99 5s w/ V6 '01 Solara Brake Conversion & 1985 AW11 MR2 5spd
Camry: Tokico Blue's w/ Ebiach Lowering Springs on Motegi FF7 17" Rims with FALKEN ALL SEASON SPORT TIRES
MR2: 7A-GE
FS: Gen 4.5 Clear lense/JVC HU&Radar
Creeps228 is offline   Reply With Quote
Old 11-06-2007, 10:01 PM   #2 (permalink)
The Flying Kiwi
papariccardo's Avatar
View papariccardo's Photo Gallery
Candles?
Check for current to the lights, if all good, check the light connections, have a spare bulb handy while you do this. Must be a PITA, huh.
Or trade on a gen6 on 18"s -
3.0G Gen 3 wagon, TCS 7str (JDM), Nissan Z32 Twin Turbo 2+2 5sp Targa (JDM)
papariccardo is offline   Reply With Quote
Old 11-06-2007, 10:02 PM   #3 (permalink)
xet
View xet's Photo Gallery
By new foglights do u mean oem replacements? If not you will have the hole in your bumper if yours are oem... But if you mean aftermarket Im personally very interested in getting some hid fogs
1998 camry xle v6 *no longer mine*
2005 G35 coupe 6mt
xet is offline   Reply With Quote
Old 11-06-2007, 10:03 PM   #4 (permalink)
Royal Dreamz cc.
CJ Otey's Avatar
View CJ Otey's Photo Gallery
if u have relays on them u should check them if not check your ground
Two Toned 97 camry w/gen 4.5 front end conversion and 20" wheels and 2 Alpine Type R 15's in a vented box pushed by kicker zx1000.1
CJ Otey is offline   Reply With Quote
Old 11-06-2007, 10:27 PM   #5 (permalink)
Creeps228's Avatar
But the thing is that, while i was driving with them on, one was working fine, where the other was turned off. SO not to looking stupid while driving even though i had them on, i turned it off to fix it when i got home, but then when i got home adn parked the car they didnt work at all, but the fuse isnt burned out, ground most be there since i never had a problem with them before. I have a current tester but im not sure its going to work, also i remembered the other question(s) they are now on the first post.
xet they are aftermarket ones
MR2: 7A-GE
Old 11-06-2007, 10:35 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
where did u get the lights? chances are the wiring is bad or the bulbs are gone. chack the wiring first for any shorts. if there are no shorts then its gotta be the bulbs. either replace the bulbs or get new lights. bulbs will of course be cheaper but this may be a chance to upgrade if u wish.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-06-2007, 10:47 PM   #7 (permalink)
Creeps228's Avatar
i was thinkin of gettin new foglights since the ones i have are all cracked but which ones will you suggest i should get because the current ones i have on the car dont fit inbetween the gaps on the bumper
MR2: 7A-GE
Old 11-06-2007, 10:56 PM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
well u have 3 choices. get the OEM bumper that has fogs built in, get really thin ones that will fit or do what the guy i bought the car from did and cut out part of the lower grille to make them fit.
R.I.P.
Car Domain:
Old 11-06-2007, 11:04 PM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
well on a totally un related search...look what i found
http://www.trucknvans.com/Pilot_Cust..._p/pl-115b.htm
R.I.P.
Car Domain:
Old 11-06-2007, 11:14 PM   #10 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Things change over time. If you decide to troubleshoot these check the wire connections (I second checking the ground but check the positive too, just in case...) and clean the scockets (make sure that the power is off) and the bulb bases. If you have decided to replace them you will probably have to remake all of these connections anyway and they will get cleaned.
Kep
Kep
Old 11-06-2007, 11:41 PM   #11 (permalink)
Noob
View gladis's Photo Gallery
I found these cheapo ones online, are they any good?
http://cgi.ebay.com/ebaymotors/92-96...spagenameZWDVW
gladis is offline   Reply With Quote
Old 11-07-2007, 12:58 AM   #12 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
those are the one my brother has on his accord.. cough up about 85 dollars from a local parts store..
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 11-07-2007, 10:14 AM   #13 (permalink)
Creeps228's Avatar
OEM bumper is not an option since im going ot be buying a body kit soon, um i really dont want to cough up more than $50 on foglights, i did see some 2"/1.25" foglights on ebay will this clear the gap? I'll try to check connections tomorrow if not the lastest will be friday
MR2: 7A-GE
Old 11-07-2007, 10:22 AM   #14 (permalink)
I HAS BOOST!!!
bigbird's Avatar
wait...if ur gonna get a body kit why would u want new fogs now anyways? if the lights are broken rip that crap off and wait till u get the body kit then get a set of lights that will fit in that kit. save ur self 50+ bucks and alot of hassle of buying 2 sets of lights or a set that will look like crap in the kit.
R.I.P.
Car Domain:
Old 11-07-2007, 11:32 AM   #15 (permalink)
Creeps228's Avatar
Its either going to be REV Kit or Evo 4/Kombat rear Bumper Either way im putting the foglights in the middle
MR2: 7A-GE
Considering a Tacoma, question a plenty! Answers much appreciated! ham'n'jam 1st Generation (1995.5–2004) 18 01-27-2006 05:03 AM
95 Camry questions erioshi 3rd & 4th Generation (1992–1996 & 1997–2001) 0 01-06-2006 04:02 AM
Exhaust system questions Brujo Camry & Solara Lounge 3 11-29-2005 09:05 PM
couple installation questions. (simple?) Celica4life Celica Forum 3 03-07-2004 05:05 PM
Answers lead to more questions Mr.Incognito Camry & Solara Lounge 7 06-12-2002 05:24 AM
