5sfe makes Tickin Noise Under Load?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2007, 07:44 PM   #1 (permalink)
View mikemustang289's Photo Gallery
Car is 2000 camry. When the car cruising, say 2k rpm, and I give it a little gas I hear a tick..tick..tick..tick...almost sounds like a valve ticking, but as soon as I release the gas a little, even though the rpms are the same, the ticking goes away. So I don't think its a valvetrain issue? Whatelse could it be?
Is it possible this is a knocking issue due to the gas? I run 87 octane, but from what I've read here there's no need to run more than. Or is this common with the 5sfe??
mikemustang289 is offline   Reply With Quote
Old 11-07-2007, 08:18 PM   #2 (permalink)
View SmartedPanda's Photo Gallery
It's a bomb! Run! =]
I dunno, never heard it in any of my cars before. Chasis noise?
1992 Camry. 4dr Sedan. 3rd Gen.
2.2L 5S-FE I4, with ~167K Miles.
Trying to get my baby restored...
So Far: Dual XHD-6425
SmartedPanda is offline   Reply With Quote
Old 11-07-2007, 08:20 PM   #3 (permalink)
Not Chasis noise, its load dependent. If I take my foot off the gas, no ticking, when I apply gas (load) tick comes back. RPM Barely change. So I don't think it has anything to do with the valvetrain as it's moving the same speed regardless.
Old 11-07-2007, 08:50 PM   #4 (permalink)
View TMetalMan's Photo Gallery
A while back my 5sfe would make a strange ticking noise that was kinda faint. If my memory serves me correctly, it too only occurred upon acceleration. On top of that, I would occasionally smell exhaust inside the cabin even with the windows up. The cause of my problem was a small-ish hose that came disconnected, from what my dad and I concluded was part of the pollution control system. It's located at the very back and at the very top of the engine compartment, just a little to the left from the center. It required me to put a zip tie on the hose to keep it connected (the nipple for this hose points down, so gravity was pulling the hose off of the nipple).
TMetalMan is offline   Reply With Quote
Old 11-07-2007, 08:57 PM   #5 (permalink)
View nitehawk55's Photo Gallery
It will probably be a small exhaust leak ( manifold/hose/gasket ). If it's an automatic try brake torquing it a bit stopped and see if it makes that noise . If you can get someone to help that makes it easy to find .
nitehawk55 is offline   Reply With Quote
Old 11-07-2007, 08:59 PM   #6 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
I'd check the exhaust for leaks. There's a couple of ways to check it.
1) Go to the tailpipe with the car running, and place your foot over the opening. You should feel a lot of pressure. If you feel little pressure, plus you hear the ticking....you have a leak.
2) With the car running (be careful with this one) open the hood and feel around the head/manifold for direct heat and air blowing. Be careful not to actually touch the metal, or it will burn you. Then check down the cat, and work your way back.
eurohazard is offline   Reply With Quote
Old 11-07-2007, 09:53 PM   #7 (permalink)
Hmm. that sounds like it could be it. You know, I've had this problem before on my ford and I kept thinking it was the valves, but it was an exhaust leak. I don't know why that didn't cross my mind this time around. I'll check that out for sure, It is a 5spd btw. It makes sense, more gas=louder combustion. That's why under no load I can't here it. I'll check that out. Thanks!
Old 11-08-2007, 08:22 AM   #8 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Sounds like pre-ignition ticking/pinging. I would check the operation of your EGR valve.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-08-2007, 10:13 AM   #9 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
check ur flexpipes, thoes usually develope leaks before anythign else..
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-08-2007, 10:57 AM   #10 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
i have the same noise so i talked to my shop instructor (master tech for chevy for a good 30+ years) and he said most likely it just the injectors firing off.. he didnt do any diagnostic or looked under the hood.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 11-08-2007, 12:38 PM   #11 (permalink)
Pimpin the Lesbo Blue Cam
View pudbrother's Photo Gallery
ive a got a rough/tick noise as well, but it does it constantly until i rev it over 2.5-3k rpms, any ideas?
pudbrother is offline   Reply With Quote
Old 11-08-2007, 03:29 PM   #12 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
I would still try changing to 89 or 91 to see if it changes.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 11-08-2007, 10:05 PM   #13 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I dont mean to thread-jack either..but I have a ticking-type noise from the engine right when it's getting ready to switch gears. It's an automatic...and you know when you are accelerating at a non-aggresive speed so that it shifts somewhere between 3-4000RPM, and it kindof hangs at an RPM for a second before it changes gears? That's when mine does it. Is this normal for this engine or is it something I need to be concerned with? It's done it for as long as I can remember.
Thanks guys.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-10-2007, 01:08 AM   #14 (permalink)
Hmm, I'll check the EGR as well.
93 22RE Ticking Noise under load Chuck_Sirloin 89-95 Toyota Pickup/Hilux 11 10-04-2007 01:04 PM
2003 Tacoma Engine Noise Planalp 1st Generation (1995.5–2004) 4 01-16-2007 09:45 PM
Worsening Noise In Engine lloydjv Celica Forum 2 02-09-2004 05:36 PM
front end groan squeal noise jcarol Archived Corolla threads 1 07-07-2003 08:04 AM
ENGINE NOISE ON 5SFE walraven Hardcore Tech and Competition 4 09-10-2002 07:47 AM
