Going Downhill. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2007, 08:30 PM   #1 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
Going Downhill.
Okay It's just a question I've always been wondering and never found a real answer to. I hear both sides.
Is it okay to Shift down in your car when going downhill?
(now that i have a car with Overdrive) is it okay to turn off overdrive when going downhill to slow your decent?
deezeejoey is offline   Reply With Quote
Old 11-07-2007, 08:34 PM   #2 (permalink)
The Flying Kiwi
papariccardo's Avatar
View papariccardo's Photo Gallery
Both sides? One side is wrong. Not only is it OK, it's advisable. You will gain a lot more stability, therefore be a lot safer. Whats worth more, the life of you & your passengers, or the car? OD on/off is a button for that very reason - feel free to use it. Same going uphill, less strain on the motor in 3rd than OD. I have manually shifted auto trans ever since I started driving, gear position is a major player in vehicle stability.
Also, remember this car is a Toyota, not some Chev or Ford. Much more reliable, much better gearbox.
3.0G Gen 3 wagon, TCS 7str (JDM), Nissan Z32 Twin Turbo 2+2 5sp Targa (JDM)
papariccardo is offline   Reply With Quote
Old 11-07-2007, 08:37 PM   #3 (permalink)
Newbie
deezeejoey's Avatar
cool thanks, some people told me that it was bad for the transmission
Old 11-07-2007, 08:50 PM   #4 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
If you're doing 125 mph, I wouldn't drop it into 3rd or anything like that. But I very often downshift at reasonable speeds in traffic if I don't feel like hitting the brakes. (I wish I had a 5 speed manual!)
eurohazard is offline   Reply With Quote
Old 11-07-2007, 08:54 PM   #5 (permalink)
View TMetalMan's Photo Gallery
It is my understanding that you should not use the engine as a brake when you are running with a manual tranny. The reason being that the clutch will wear in the opposite direction it was made to, which will cause it to wear out faster. But I could be wrong, as I have yet to own/drive a car with a manual tranny.
TMetalMan is offline   Reply With Quote
Old 11-07-2007, 09:10 PM   #6 (permalink)
View nitehawk55's Photo Gallery
Total hogwash
nitehawk55 is offline   Reply With Quote
Old 11-07-2007, 09:12 PM   #7 (permalink)
Newbie
deezeejoey's Avatar
Well as far as speeds, it's a big, long hill.
the speed limit on it is 35 mph. but coasting you can easily get up to 80 MPH
So i'm talking about down shifting at about 55MPH
I used to drive a dodge, and i think we all know their rep with transmissions. I had to get mine replaced in the shadow last year. I got lucky tho. got a great deal. Refurbished tranny installed for $600.
Old 11-07-2007, 09:30 PM   #8 (permalink)
The Flying Kiwi
This may be true (never heard so before tho), and certainly you would expect a little more wear in an auto as well. Not enough IMO to justify not downshifting. From a safety/ performance point of view, being in the right gear for the condition outways any such constraints. I drive a 400+ hp car on the road and track, and use the clutch constantly. My auto beater Camry also gets plenty of downshifts as needed, & it won't shift down if you are travelling too fast for the selected gear anyway. OD on/off is the most common switch I use in my Camry, after indicators. That hill you speak of is a classic example of when to switch OD off.
Old 11-07-2007, 09:57 PM   #9 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
if i need to slow down going down a hill i just use that big pedal on the left. i would rather wear the brakes down than give more wear on the engine and tranny.
Old 11-07-2007, 10:10 PM   #10 (permalink)
True, but if you ride the brake all the way down a long hill, there's a chance you could warp your rotors from too much heat. For an auto, I think a combination of being in a low gear and using the brake to get down a hill is the best option.
Downhill And Hill-Start Assist Control Systems Enhance Off-Road humanoid Toyota News 1 10-06-2007 05:52 PM
Downhill Assist Control Retrofit Synchman 2nd Generation (2005+) 27 08-23-2007 07:07 AM
Drown Shift While Coasting Downhill? zzCamryzz 5th & 6th Generation (2002-2006 & 2007-2011) 7 05-31-2007 09:50 PM
Downhill: Neutral or engine braking PA452 General Discussion 33 05-22-2007 10:07 AM
Camry downhill battle CX889 Camry & Solara Lounge 8 11-13-2005 11:27 PM
