Has this been done yet?? (Electrical) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2007, 09:53 PM   #1 (permalink)
View SPooNGTP's Photo Gallery
3rd Generation Has this been done yet?? (Electrical)
Looking to add some electrical features to my 92 Camry i recently bought
i have already added HID's to the car and noticed when the door is opened with the key out the headlights shut off..
what i was wanting to do is extend that feature to allow the radio to continue playing and windows to be controlled after the key has been removed from the ignition until the door is opened.. have this feature in my 97 grand prix and miss that in the Camry..
SPooNGTP is offline   Reply With Quote
Old 11-07-2007, 10:10 PM   #2 (permalink)
Gameroom cash: $115825
View abew330's Photo Gallery
my guess would be to use some type of relay or something
maybe wire up a constant 12v with key in and shuts off when the door triggers are active if key is out.. something along those lines
its in my silverado as well.. nice to have
but would be a hassle to wire up in a camry i think
Old 11-07-2007, 10:29 PM   #3 (permalink)
should be fairly simple most should be able to be done at the fuse/ relay box but havent looked into it much yet ill have it done within the next week and let you all know how it goes im just hoping somebody else has done it already would be a nice time saver as im not yet familiar with this car
Old 11-07-2007, 11:17 PM   #4 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Check the wiring diagrams on the '96 Camry's. They have a 60 delay for the windows, or untill door is opened.
5 Lug Corolla WHAT?
Old 11-08-2007, 12:10 AM   #5 (permalink)
Lightbulb
For the power windows:
There is a sort of master control wire, which receives 12V from the ignition switch, and allows the power windows to be active. Actually, the circuit gives you a 60 sec. period after the IGN switch is turned off when windows are still active. .... Not much trouble to just wire an additional manual switch so that windows are active all the time until turned off. ...
For the radio:
Again, it looks like there is one particular wire which requires 12V to activate the radio.
So, to get the radio to work without the ignition key, you could just install a manual switch ... Little effort required.
The radio illumination appears to be independent.... would require additional effort. ...
To get the windows and radio to turn off when you open the driver's door, you might have to install an independent plunger switch in the door channel someplace... ... Automatic Headlight turnoff circuit is not really available to modify.... You wouldn't want the headlights on all the time.
So, it might work like this.
To activate the long term 'IGN OFF mode' for the power windows and radio, you would have a manual switch on the dash for each ... push button, toggle, or whatever.
If the long term function switches are turned ON, the radio and power windows would operate and be active, even with the IGN switch turned off. Opening the driver side door would immediately deactivate the radio and the power windows would deactivate in about 60 sec.
IF the panel switches are OFF, then you would have normal turn off of the radio and power windows.
There would probably be two wires going to the plunger switch in the door channel ... one for power ... the other to signal that somebody is actually in the car ... and has had the ignition switch on. ... Would use an SCR to keep the radio and window off after it had deactivated initially. That is, you would have to turn the ignition switch on again to get the radio and windows.
... Is this generally what you wanted? Would it be adequate ... or what?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-08-2007, 01:02 AM   #6 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
My windows do that already, and the radio thing seems silly to me. If you were listening to the radio, you have to stay in the car which defeats the purpose of having it stay on without the key as if you were staying in the car you would want AC/heat. Also, my stereo will cut out running on just the batt... But hey, that's just IMHO
Blackhawk3D is offline   Reply With Quote
Old 11-08-2007, 01:36 PM   #7 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
^I think he means it like in some GM vehicles, the radio stays on when you turn it off until a door is opened.
BlueFusion6851 is offline   Reply With Quote
Old 11-08-2007, 02:21 PM   #8 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
yeah, my dad's work van does.
deezeejoey is offline   Reply With Quote
Old 11-08-2007, 03:34 PM   #9 (permalink)
MOUTH SLAP!
Your Uncle Moe's Avatar
View Your Uncle Moe's Photo Gallery
You windows already have that feature but it is temporary. My 96 has it at least, If you shut the car off and pull the key out, as long as no one opens their door you can control your windows and moon roof for a minute. Then it stops functioning.
96 Camry V6 LE & 90 Eagle Talon TSI (AWD TURBO)
"Love is all you need to know and all you need to know is love is all you need to know."
Your Uncle Moe is offline   Reply With Quote
Old 11-08-2007, 05:23 PM   #10 (permalink)
what I was saying is that it'd be alot of work for no real reason. I don't even get why the GM ones do it (and I know what he's talking about, I drove my dad's Silverado for a year) It always just goes off as soon as you get out anyway, and if you were wanting to sit in the car and listen to music you'd have to have the motor running for any decent system anyway. But to each his own, yada yada. It'd be a cool trick but not worth the effort IMHO.
camry96 electrical wiring 1996camry 3rd & 4th Generation (1992–1996 & 1997–2001) 1 07-11-2007 07:31 AM
pre-Cressida 22R electrical issues DR1665 Cressida Forum 4 05-31-2006 12:18 AM
gotta be something electrical!! bad7mgte Supra Forum 5 12-07-2004 07:26 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
Total Electrical System Failure sargeusmc57 Camry & Solara Lounge 0 12-21-2002 03:55 PM
