98 Manual tranny - Unexplained engine revving
Hello all,I have a 1998 2.2L Camry manual 5 speed. Since I purchased this car 3 years ago, it has always had a very annoying habit whereby the engine revs increase when I depress the clutch to change up to the next highest gear.
For example, if I'm changing from second to third, I generally change up at around 2800 RPM. When I release the accelerator pedal and depress the clutch, the engine revs will often increase by 200-300 RPM for 1 to 3 seconds before it then begins to drop back. This really makes the gear changes very jerky unless I wait a few seconds until the revs drop down before I engage the higher gear.
Several Toyota dealers have told me that this over-revving occurs because of North American pollution control requirements (something about burning residual fuel in the inlet manifold) . I don't believe this because I have had several manual 5 speed cars and I have never seen this type of over revving on any of them.BTW, this over-revving only occurs when the engine is warm.Any suggestions for diagnosis would be greatly appreciated.
