HELP Gen 4 Timing belt??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2007, 12:39 PM   #1 (permalink)
View MattyBizzle87's Photo Gallery
4th Generation HELP Gen 4 Timing belt???
i have a 1997 toyota camry V6 with 87k miles on it...everytime i go to my machanich he says i gotta go the timing belt or i could have some serious problems....is he being honest has any of you camry owners had there timing belt go...or had it replaced. HELP me please befor i drop 700$ on this fix
MattyBizzle87 is offline   Reply With Quote
Old 11-08-2007, 12:47 PM   #2 (permalink)
Replacement cycle on V6 is 90k mi.
Also get new water pump.
... price sounds about par... unless you want to try it yourself.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-08-2007, 12:49 PM   #3 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
What was the mileage when you last replaced the timing belt? Camry's need to have their timing belt replaced between 70,000-80,000 miles, that is depending on the last time you replaced it, if you followed the toyota recommended service schedule than its time to replace it. But let me tell you that a timing belt replacement is nothing you should put off, if a timing belt breaks then your engine will pretty much destroy itself.
camry man68 is offline   Reply With Quote
Old 11-08-2007, 02:02 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I was under the impression that all Camry engines were the "non-interferance" type. When a Camry timing belt breaks the engine just dies and you coast to a stop (if you were moving). There is no damage done to the engine but you do wind up stranded where ever you wound up (if that is in the middle of a busy road you are in a heap of trouble).
Kep
Old 11-08-2007, 03:01 PM   #5 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
^ I know you're right about the 5S-FE, but I don't know about either the 3VZ or 1MZ.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 11-08-2007, 03:23 PM   #6 (permalink)
wtftoy's Avatar
View wtftoy's Photo Gallery
1MZ are non interferance. Hoping to reach 95k before doing the timing belt and water pump. What else should I have the mechanic look at?
BTW the shop I go to charges ~$500 for timing belt and water pump.
1998CamryLEV6
Tokicos,Eibachs,TrdRSB,Intake,Jim'sTorqueRod.
wtftoy is offline   Reply With Quote
Old 11-08-2007, 03:30 PM   #7 (permalink)
There are one or two idler pulleys to inspect ... might not be critical on the first new timing belt though.
Old 11-08-2007, 03:42 PM   #8 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
1st thing 1st, the 1MZ is actually an interfereance engine I found out not too long ago, but is so well built, the timeing belt breaking will only do damage if it breaks over 5k RPM's on full throttle.
Change the 1MZ belt around 90k miles. With it, Change:
1: Water Pump
2: Crank seals, gaskets
3: Tensioner
My personal mechanic refuses to do it unless you agree to have him replace it all.
Also, Use OEM Toyota parts for this. Too many crappy aftermarket ones.
5 Lug Corolla WHAT?
Old 11-08-2007, 04:11 PM   #9 (permalink)
Gameroom cash: $303055
Try to find a dealer in your area that has a timing belt change special for the V6, using the link below. $700 sounds very high to me. I know that dealer specials for the I4 timing belt are usually $199. The V6 may be a bit more. Add to that the cost of the water pump (if you decide to have that done at the same time) and about an additional hour of labor:
http://www.toyotacoupons.com/UI/Deal...lerSearch.aspx
Mike
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
anybody ever have a timing belt brake on a gen 4 solidg 3rd & 4th Generation (1992–1996 & 1997–2001) 7 03-12-2007 12:10 PM
gen 2 v6 timing belt replacement smkdwnn 1st & 2nd Generation (1983–1986 & 1987-1991) 12 05-21-2006 10:10 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
81 Celica and Timing Belt GregAt99 Celica Forum 3 05-10-2003 12:09 PM
