uuh....why do you have to turn on your lights?! Don't your P-R-N-D-2-L on the instrument cluster still work?
And dont you just know where the gears are? Im mean..if you're going backwards...you're in reverse. If you want to go forward...just slide the shifter down without pressing the button till it stops...then you're in Drive. If you need to put it in park..it's all the way forward. Why does one need to actually LOOK at the gear shift?
If those lights went out...I could care less.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
