fuel gauge problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2007, 10:31 PM   #1 (permalink)
Rubbish.
jsl222's Avatar
View jsl222's Photo Gallery
fuel gauge problem?
Ever since I've had my car(6000) miles, the fuel gauge has cease to work properly...I think. Either the car is getting 5 miles to the gallon or something is up. The needle drops drastically in a short period. I filled my tank full 2 days ago and approximately 40 miles after,today, the needle is near the half-way mark. I'm thinking maybe it's time to replace the o2 sensor? Any one have any ideas? Thanks
jsl222 is offline   Reply With Quote
Old 11-08-2007, 10:35 PM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
More details on the car... v6, i4? year? How many total miles on it? Last time you did maintainence? What did you do?
A few potential problems...
Try resetting your ECU
O2 sensors
Fuel filter
Plugs
Caps/Rotors
Tires under inflated
clogged cat
if all those things are in order then its the gauge.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 11-08-2007, 11:03 PM   #3 (permalink)
Rubbish.
jsl222's Avatar
It's a 95 i4 with around 184200 on the odo. last time I had it serviced was a month ago for a brake fluid change. It does need a tune-up, but not badly. I was also thinking the fuel filter could be causing it.
Old 11-09-2007, 07:19 AM   #4 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
next time you fill up the tank, calculate the fuel economy. that will tell you if the gauge is wrong or if its something else.
Old 11-09-2007, 07:30 AM   #5 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
I would do what ^^ said.
But an obvious way to know if your car is getting bad gas mileage or just an incorrect gauge, is to see how much fuel you put in after driving 40 miles. If you're putting in 10 gallons or so for only 40 miles, then something is up.
geoff5093 is offline   Reply With Quote
Old 11-09-2007, 03:37 PM   #6 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
You may have a fuel leak somewhere..and since gasoline evaporates so quickly...you may not see it drip on the ground.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-09-2007, 04:33 PM   #7 (permalink)
Rubbish.
jsl222's Avatar
no leak. i've checked under the car when it was running
Old 11-09-2007, 04:43 PM   #8 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
my second guess. it could be the fuel level sending unit.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 11-10-2007, 04:03 PM   #9 (permalink)
Rubbish.
jsl222's Avatar
I noticed that the needle rises also. I had half a tank when I left the house today and after 50 miles of driving, it was all most at 1/4 mark. When I was pulling up to the drive way, it rose a bit. Anyway I'm gonna go get it checked in a couple days
Old 11-11-2007, 11:25 PM   #10 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Do what ghetosled suggested. You know how many miles you have run since your last filll. Go to a gas station and fill up again. If, like it sounds, you have run 90 miles since your last fill and you need 3-4 gals of gas then your fuel economy is OK and your gauge is bad. If you need more than 4 gals then your gauge may be OK but your fuel economy is poor. At a quarter tank I think I need about 12 gals to top off my tank.
If you haven't kept track of your last milage and fill up data then go and fill up now and keep track of your odometer. Your should be able to determine your milage at the next fill after that. You can get an accurate fuel economy figure after about 40 60 miles.
If it is your fuel gauge then an O2 sensor or a fuel filter will not help. If you are indeed getting 5 mpg then your definately have a problem. I'm not certain but a 20-25 mpg improvement because of a newO2 sensor seems a bit optimistic.
Kep
Old 11-12-2007, 11:21 AM   #11 (permalink)
ghettosled's Avatar
most fuel gauges change depending on the angle of the car.
Old 11-30-2007, 03:48 PM   #12 (permalink)
Ballin Ass Camry
stewart591's Avatar
View stewart591's Photo Gallery
this same thing happened to me took it to christian brothers auto and the guy said it was the SENDER UNIT. and that it is a costly fix
stewart591 is offline   Reply With Quote
Old 11-30-2007, 07:29 PM   #13 (permalink)
Rubbish.
jsl222's Avatar
How much?
Old 11-30-2007, 07:59 PM   #14 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
Rather than o2 sensor I would look to engine coolant temp sensor. Is the trans shifting into O/D? But first you need to do as suggested, calculate your mileage. Before I'd go changing the fuel sender I'd look at the gauge.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 11-30-2007, 08:30 PM   #15 (permalink)
Black95Cam's Avatar
the fuel level sending unit sends info to the gauge which display it. so if the sending unit is giving false reading thus the gauge will be off.. unless there something else that affect that gauge that i dont know off.
Surging - Fuel Problem? 97trdcamry 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-09-2009 07:53 AM
Mechanical Oil Pressure Gauge Install Stillrunning 3rd & 4th Generation (1992–1996 & 1997–2001) 0 09-05-2007 05:12 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
Fuel Gauge problem 94 Tercel enerjohn Tercel, Paseo, Starlet, and Sera Forum 9 12-05-2005 08:57 PM
Fuel gauge problem... TRD 4Runner Off Topic 0 12-11-2001 09:38 PM
