I got some touch up paint from my local Toyota dealer.
Question is now, for those small ships from rocks hitting the hood, how do i remove the rust before i put the paint on?
O, and i managed to get A picture off before my camera's battery died.
Reason: added picture.
best bet is to get some masking tape and some newspaper and some sandpaper in a couple different grades from semi rough to fine. Sand the rust away and then use the finer grades to feather it out into the older paint. Mask it off, primer it, fine sand it, paint it, sand it again, then hit it with clear. Sand with fine grade and hit it with some polish. Done and done.
Originally Posted by DarkMastyr
Is it just me, or has TN just become this massive gay fest? It's like you can't avoid the hot gayness in every thread.
For the smallest "specks" that are starting to rust, I use a pencil eraser. Try it. It works well removing rust.
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Yes, I've also seen some people gluing very small pieces of sandpaper to a pencil eraser to precisely sand down real small areas.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Use 1500-2000 grit wet sandpaper and just rub the area lightly until the rust is gone... You'll probably need to go over it with some rubbing compound because the sandpaper will scuff up the clear coat, but any decent rubbing compound will make it shiny again!
