How do I get the trans pump front seal out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2007, 04:28 PM   #1 (permalink)
View mlmack's Photo Gallery
Ok so I finally got the old 5sfe eng out and swapped all the stuff over. I resealed the new eng and will put the new flywheel on soon. But I cant get the Trans pump front seal out. First can I just pry it out or do I have to remove the pump and drive it out on the bench. Any help would be appreciated.
I fly high, no lie
mlmack is offline   Reply With Quote
Old 11-09-2007, 05:08 PM   #2 (permalink)
Probably you should take a look at the online repair manual section AX ... I4 auto transmission.
There is a note ... 'remove second coast brake piston before removing oil pump'.
See p. 37 ...
... Just looking at the manual here. ...
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 04-13-2008, 12:50 PM   #3 (permalink)
View luckydog700's Photo Gallery
trnas front pump removal
I got mine out ('94 Camry, 4 cyl, A140E) by putting bolts into the two threaded holes in the front plate and using a puller. The other holes in the plate are not threaded; only two of them have larger threads that the installation bolts do not screw in to.
Rick
luckydog700 is offline   Reply With Quote
22R Front Crank Seal. 1981. 2WD. pursang Pre-88 Toyota Pickup/Hilux 9 10-27-2007 07:24 AM
Whiteline MA70 Front/Rear Adjustable Swaybar GroupBuy!! raptorracing Supporting Vendor Sales 30 04-27-2007 03:27 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
Seal, timing belt, water pump, mounts fair price TonyD Camry & Solara Lounge 8 03-06-2005 12:07 PM
4a-ge crankshaft front seal bondobondo Archived Corolla threads 1 01-19-2002 01:53 AM
