3rd & 4th Generation (19921996 & 19972001)Toyota Camry Discussion for years: 1992-1996 & 1997-2001
Im thinking about retrofitting my 94 xle's headlights with projectors and an HID set up and i have a few questions
A) For the HID kit , do i just get the 9006 HID Kit or do i need another bulb fit ment?
B) I have standard weak halogens in my car and i was wondering would the 6000k Bulbs be alot brigheer?
C) I'm thinking about getting this set up
HID Kit: http://cgi.ebay.com/ebaymotors/HID-X...em270184567445
get these projecotrs, the first link. since u have 9006 and 9005(high beam) then gettting bi xenon will be usless unless u get a bi-xenon HID kit and redo the headlight harness. u can save alot of time and money but just getting the 9006 kit. http://cgi.ebay.com/ebaymotors/set-o...em230188408160
since u have a gen3 then u can get the depot clear headlights(also on ebay), definatly better to have thoes with the projectors. if u get d2s(bulb type) projectors then ull have to get d2s bulbs to fit. u still want a 9006 HID kit though.
okay confused.
i want to keep my orignal headlamps- im just going to sand it down and clear them up with plastic x and wet sand
i just need help on the proper kit and proper projectors ( trying to minimize my budget here) anyone can help?
you dont. the closest ull get is get depot clears to get rid of all teh ribbing in the lights and get a $50 set of sylvania silverstar ultras(think thats their new ones). and that still a far cry from HID but its brighter and whiter. i personally really like that look to.
Definitely don't get that cheap ass "HID kit". Seriously, you don't want to skimp out on HID kits. As for the retrofit you're going to need to do, I believe there are some writeups somewhere in this forum for a DIY project. I know TonyTheTiger has done the retrofit, as well as a few others.
+1, the cheap kit I bought had many issues, most of the time one of the bulbs wouldnt come on (probably a faulty ballast), and other times I had to flick the switch several times for it to come on. Then I was flashed by other cars every so often.
okay so if i do get a HID Kit i should get a quality made/brand one?
and im thinking about getting those Audi A6 Projectors?? sounds like a good deal?
If you do want a kit, I would highly recommend XenonDepot. They use quality bulbs and ballasts, which also include all the relays you will need.
And you do know it takes a lot of work to retrofit projectors, and wiring it up right? It's not like you can just take A6 projectors and cut a hole in the headlight, then mount it. Besides, i'm sure A6 projectors are crazy expensive, I would go with TSX projectors.
okay when i get the projectors do i need shrouds(sp?) with them or what?
and i buy the 9006 HID Kit right
If you are retrofitting projectors, then you wouldn't use an HID kit. 9006 is the size for the stock bulb, the projectors from the A6 or similar cars would use a different bulb.
