Originally Posted by wahed3001
Thanks for the info. One more question: When I install a new gasket on the transmission pan, do I need to apply any sealant such as weatherstrip cement?
The negative factor with sealant is that some of it might come off inside the pan and clog the filter/strainer. ... Not really likely .... but possible.
I did not use any sealer ... I used an OEM gasket from the dealer .... $18 or so.
No problems or leaks ... Just be patient with the multiple pan bolts. Tighten each bolt partially ... and repeat going around the entire bolt pattern several times.
Recommended final bolt torque is something like 5 ft-lb.
Also, take a few minutes and clean out any sludge or debris in the bottom of the transmission pan. ...You could remove the strainer and rinse, also.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
