Problems with a 94' Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2007, 02:05 PM   #1 (permalink)
View DiRtY-D's Photo Gallery
Now I have absolutely no knowledge as far as cars go. I had purchased a 94' Camry and it has ran perfectly for a year and a half, purrs like a kitten. Now to start off, I recently had my transmission (automatic) changed (the one before wouldn't shift, even when you moved between Reverse and Drive or Neutral you would feel it on the car, if you tried to accelerate in Drive the RPM's would go up but the car would not move.) As soon as it was changed the problem was solved, now the strange thing was that with this new transmission when I shift into Reverse I hear and feel a "thud" at first I thought nothing of it but it has begun to worry me so specially because now whenver I press the brakes the "Reverse" Gear Light turns on (the one right next to my spedometer). Even when the car is off if I begin to press the brake it will turn on. Now I have already established that a few of my brake lights are malfunctioning and I am planning to replace that.
But here is another thing, even though that might indicate that the lights are malfunctioning I dont think is should affect the way the car stops. Everytime I am driving and I have to come to a complete stop as I am pressing the break between the car slowing down at 15-0mph the car begins to shake and make a weird rumbling noise. Accelerating is no problem the automatic shifting seems to be fine, its only this weird brake and reverse light anamoly that is worriying me so. Despite all this, the car purrs like a kitten (when I am not coming to a complete stop.)
PS. The oils where all changed the day I had my new transmission put in which was a month and a half ago.
Anyone have any ideas?
DiRtY-D is offline   Reply With Quote
Old 11-10-2007, 02:54 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
First off..do you have a warranty on the tranny? Was it new, rebuilt, or a used tranny?
When you say all the fluids...do you mean the tranny fluid along with the rest?
It's possible that the tranny mount has gone bad (should have gone ahead and replaced it when tranny was out. there are 4 mounts on that engine/tranny. Check them and see what their condition is. If it is bad, it will cause that thud you are talking about.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-10-2007, 04:23 PM   #3 (permalink)
View Dadx5's Photo Gallery
Almost sounds like my problem with my son's 93 Camry. Wrecking yard trans will be installed next week. Fingers crossed on this. If I continue to have trans problems, a new car will be in the works.....
Good luck on yours
Dadx5 is offline   Reply With Quote
Old 11-12-2007, 02:20 PM   #4 (permalink)
View sdw222's Photo Gallery
I would suspect that shorts or bad grounds in the tail/reverse light fixtures are back feeding voltage to the reverse indicator on the dash
sdw222 is offline   Reply With Quote
94 to 93 CAMRY ENGINE & TRANNY SWAP cato47 3rd & 4th Generation (1992–1996 & 1997–2001) 3 10-14-2007 06:29 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
94 camry with 95 camry front bumper and rear trunk/lights? tousi 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-23-2005 04:55 PM
Problems starting 94 Camry when engine is cold RacerX001 3rd & 4th Generation (1992–1996 & 1997–2001) 4 12-15-2004 06:07 PM
94 5sfe oil/engine problems a94autoCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-20-2004 05:08 PM
