NEED help.. car starts up but wont let me shift.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2007, 03:20 PM   #1 (permalink)
View Dowd's Photo Gallery
My car is sitting in a parking lot right now. it starts but doesn't let me shift into drive.....Does and one know whats wrong. I think it might be the computer...does any one know if there is a reset or something
plz need help
Dowd is offline   Reply With Quote
Old 11-10-2007, 08:37 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
To reset the ECU...unplug the negative battery cable from the battery for a couple minutes and then hook it back up.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-10-2007, 08:41 PM   #3 (permalink)
The Flying Kiwi
papariccardo's Avatar
View papariccardo's Photo Gallery
When you depress the red emergency release button on the base of the shifter, does it engage drive? Try that 1st if you haven't. May be a solenoid or even complete brake light failure causing it. (I'm assuming the USDM cars require the brake pedal depressed prior to releasing from park as do JDM)
3.0G Gen 3 wagon, TCS 7str (JDM), Nissan Z32 Twin Turbo 2+2 5sp Targa (JDM)
papariccardo is offline   Reply With Quote
Old 11-10-2007, 10:50 PM   #4 (permalink)
View freestylez's Photo Gallery
had the same problem last week
car drives great then last thursday morning i was going to school when my car could not shift out of Park...so frustrating
theres a small black tab thats on the top next to the shift, pry it off with a screwdriver & press the button to shift into Drive
Once i got it out of Park i drove to my mechanic and found out a fuse under my steering wheel blew out
I had a feeling it had to an electrical problem because when i depress my brake pedal, the brake lights did not go on
see if youre having the same issue
freestylez is offline   Reply With Quote
Old 11-10-2007, 11:05 PM   #5 (permalink)
Check 15A ECU-IG fuse ... located in under dash fuse box to the left of steering wheel.
This is related to transmission shift lock.
Also related 15A Cig/Radio fuse and 15A Stop fuse. ... same fuse box.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-10-2007, 11:50 PM   #6 (permalink)
pro nub
View trdcamry00's Photo Gallery
had this problem before also. It was either a 10 or 15 amp fuse located near the steering wheel also. My dash also went out too at the same time. hope you get it figured out.
trdcamry00 is offline   Reply With Quote
Old 11-11-2007, 02:30 PM   #7 (permalink)
The Flying Kiwi
Aha, another difference between the markets, Japan has a small red button in the same spot.
Old 11-11-2007, 03:39 PM   #8 (permalink)
yeah thanks every one for ur help i got it fixed
Old 11-11-2007, 04:11 PM   #9 (permalink)
what was the problem?
MKIV Scam registry bmw5002 Supra Forum 11 07-09-2010 11:59 PM
Clutch rattling when car starts custum Older Generations (1969-1987) 2 10-12-2007 12:20 AM
2007 Hybrid Camry In-depth Consumer Review phenderson Camry Hybrid 0 08-09-2006 09:16 PM
2007 Camry In-depth Consumer Review phenderson Camry Hybrid 0 08-09-2006 09:15 PM
