1998 Toyota Camry CD player removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2007, 04:08 PM   #1 (permalink)
View kaejr's Photo Gallery
Whats going on? I have a 98 toyota camry and it has a factory double din deck installed right now and I would like to remove it and install a new after market unit...My question is does anyone have any instructions on how to remove the factory deck? is there an amp or does the factory unit have a built in amp? is there a security feature that I should be aware of? all the help possible would be a great help thanks again...
kaejr is offline   Reply With Quote
Old 12-01-2007, 05:07 PM   #2 (permalink)
View go1dielox's Photo Gallery
If you have plates on the side those can be popped out with screw driver and you can see the mounting screws that hold the unit in. Remove the screws and pull out and unplug.
go1dielox is offline   Reply With Quote
Old 12-01-2007, 06:01 PM   #3 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
I swapped the radios before selling my old car. This might help you
Toyota Nation, I present you my new Camry
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
Old 12-02-2007, 12:07 PM   #4 (permalink)
Gameroom cash: $303055
It's really pretty easy. First, remove the ashtray and cigarette lighter. Then pry out the panel around the whole assembly starting from the bottom outside areas and working upward. Then unplug the modular connectors for the lighter and the lights. This will expose 4 screws that hold the raido assembly in to the dash. Remove them and slide the radio forward. Now remove the antenna connector and the modular connectors from the back of the radio and you are done.
This site might help you as it has some good pictures, but will cost you $4:
http://carstereohelp.net/Str/Toyota.htm
Mike
Old 12-02-2007, 12:31 PM   #5 (permalink)
View eilros's Photo Gallery
http://www.installdr.com/InstallDocs/Toyota/Camry.html
eilros is offline   Reply With Quote
Parrot Bluetooth Handsfree Kit with Toyota harness! goldmember Car Parts for Sale 4 11-19-2007 04:51 PM
Toyota Camry Remains America's Best-Selling Passenger Car humanoid Toyota News 0 10-06-2007 03:04 PM
Toyota And Joe Gibbs Racing To Team Up For 2008 NASCAR Sprint Cup And Grand National humanoid Toyota News 0 09-21-2007 07:10 PM
Our engine is toast mvons 89-95 Toyota Pickup/Hilux 29 04-05-2007 12:50 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
