A question before topping my power steering oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2007, 06:36 PM   #1 (permalink)
View cloudsearch's Photo Gallery
4th Generation A question before topping my power steering oil
Hi, my power steering oil is a bit low and I am to top it up. According to the manual, I bought some ATF fluid saying "meets or exceeds requirements of GM Dexron II/III" from pennzoil brand.
My question now is, when I check my power steering oil in the car, it is transparant yellow, and the new one I bought is purple-ish. Can I add them together? Thanks so much for your advice or share of experiences.
cloudsearch is offline   Reply With Quote
Old 11-10-2007, 06:42 PM   #2 (permalink)
by the way, sorry for my careless double-post of the original text.
Old 11-11-2007, 01:51 AM   #3 (permalink)
Can anyone please reply?
I may need to do this soon. Thanks!
Old 11-11-2007, 02:10 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
to the best of my knowledge, it should be fine.
what you have right now is actually "power steering" fluid- usually from the factory.
but according to the haynese manual, you can put in dexron III.
personaly, I had the two mixing for a while before I finally flushed the old power steering fluid out and put in ALL dexron III
HaHa
Old 11-11-2007, 11:00 AM   #5 (permalink)
I see. Thanks. I guess I will add a little abit at a time and see if anything goes wrong. Anyway I may only need to add 1/4 qt to make the fluid level above "min".
Old 11-11-2007, 02:08 PM   #6 (permalink)
TN Pussy Man
also though, something to think about is that you probably have a leak somewhere in your system as well. Either from the rack, the pump, or from hoses (and if you have the hydraulic fans, then from the fan assembly, etc.) since your power steering system is not supposed to lose/gain any fluid in anyway.
so the fact that you have to fill up means that you're losing fluid somehow.
the same amount and fluid can be run for years from the factory.
HaHa
Old 11-11-2007, 06:18 PM   #7 (permalink)
It is a 97 camry so I think maybe it is reasonable. Also, the manual said adding power steering fluid is normal?
In addition, I have not experienced any steering problem (or I do not know it is though I felt it), should I add at all? What will be the phenomina of not having enough power steering fluid?
Thanks again.
Old 11-13-2007, 08:32 AM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
If the reservoir is low, then several things can happen that is really not good
If too much air enters system, and you loose the power assist, but that is only if it gets really low. It would make a terrible noise.
Then the pump if it is not lubricated, wears out really quickly. Some air causes foaming in the fluid and also a loss of steering assist.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
HELP: Ratcheting Noise in steering column when turning at low speeds... SIrMack 5th & 6th Generation (2002-2006 & 2007-2011) 29 11-14-2007 12:03 AM
dumb question? (power steering) jja141 89-95 Toyota Pickup/Hilux 4 07-09-2007 11:58 PM
30,000miles on single oil change(how to help my car?) Part 2 Rob-D Camry & Solara Lounge 6 10-14-2006 12:26 AM
Power steering oil leaks kjoephi Archived Corolla threads 0 10-05-2006 01:03 AM
