Operating temperature of AT - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2007, 10:08 PM   #1 (permalink)
View wahed3001's Photo Gallery
Can anyone please tell me what the operating temperature is for a 94 camry I4 transmission (A140)? If you're just back from a long drive and proceed to drain the ATF what will be the temperature of the fluid coming out? I understand it's never the same value so an approximate range will do. Anyone?
wahed3001 is offline   Reply With Quote
Old 11-11-2007, 10:54 PM   #2 (permalink)
The trans temperature is not a specified constant value. If you took one of the thermal IR temperature guns ... and made several external measurements of the transmission pan .. on different occasions , you could probably come up with an average expected temperature. However, this average temperature would change according to the particular terrain that you had driven .... more hills .... higher temperature. Ambient air temperature would also be a factor, and maybe even driving speed.
In general, the more heat that is generated internally within the transmission due to gear friction, the higher the transmission fluid temperature. ... However, there is also a transmission fluid cooler, which removes heat from fluid and lowers the temperature.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-11-2007, 11:34 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
my auto tranny A541E before I did the swap basically stayed steady at about 180F if/once it fully warmed up and basically never moved when the car was still. When the car was in motion though, the temps were drop a good 30F due to my tranny cooler.
generally speaking, when driving, the temp will go up, but my temps were moderated and lowered by a huge tranny cooler that was more effective when the car was moving (unless you get one with a fan on it)
HaHa
Old 11-11-2007, 11:41 PM   #4 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Do you have any pics of the tranny cooler?
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-12-2007, 04:27 AM   #5 (permalink)
What kind of tranny cooler were you using? Did you have a temp sensor attached?
Old 11-12-2007, 08:12 AM   #6 (permalink)
TN Pussy Man
My cooler during the summer:
My cooler during the winter:
and I had a tranny temp gauge installed when I had the cooler
HaHa
Old 11-12-2007, 03:13 PM   #7 (permalink)
What is that you attached on the cooler for the winter? What is the brand of that cooler? How much did it cost?
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
Trouble Codes abew330 3rd & 4th Generation (1992–1996 & 1997–2001) 9 02-09-2007 01:04 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
