Strut Replacement Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2007, 02:17 AM   #1 (permalink)
View simplyxtrippin's Photo Gallery
I replaced my front struts this weekend. Took me a whole day to do too due to some lack of proper tool (breaker bar) and having to replace a cv boot. but anyways, after i finished installing the new strut, i took it for a drive. At some times when i hit a bump on the road, id hear a knock on the front pass. side corner of the car. Would an old mount cause this? i didn't change the strut mounts because it looked fine when i changed it. What else could've caused this?
simplyxtrippin is offline   Reply With Quote
Old 11-12-2007, 04:08 PM   #2 (permalink)
View alienboy2k's Photo Gallery
sounds like the strut tower (mount) is broke....easy fix (if you take the struts out)
alienboy2k is offline   Reply With Quote
Old 11-12-2007, 06:00 PM   #3 (permalink)
thanks alienboy2k
I've been looking around for strut mount (i never knew how expensive they are) and some of them have a "bearing" that's shaped like a ring. When i replaced the struts, we (me and my dad) didn't even notice this. And in the manual, it didn't even mention this. Im confused.
Does anybody else think that its the mount that's causing this noise? or is it something else. Any replies are welcomed and appreciated. thanks.
Old 11-12-2007, 06:17 PM   #4 (permalink)
View mitsujh's Photo Gallery
hey, i have the same problem, just had all my struts changed yesterday and now theres a loud knock on the rear drivers side. told the mechanic to check it, and he said its the strut mounts, gonna get them changed this weekend.
mitsujh is offline   Reply With Quote
Old 11-12-2007, 07:03 PM   #5 (permalink)
Its been several years since I fixed mine, but if i remember right, if you had a new one in your hands, and an old one, you would see the problems. I think mine was cracked and it had a little bit of play in it which causes that "clunk" It was real hard to see the problems until I had a new one to compare it to.
Old 11-12-2007, 07:37 PM   #6 (permalink)
View nitehawk55's Photo Gallery
Expensive as the strut mounts are it's probably a wise move to do them when you replace the struts .
nitehawk55 is offline   Reply With Quote
Old 11-12-2007, 09:03 PM   #7 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Originally Posted by simplyxtrippin View Post
thanks alienboy2k
The gen 3 (92-94) didn't have the steering bearing in the strut mount, but the gen 3.5 (95-96) did.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 11-13-2007, 01:38 AM   #8 (permalink)
mitsujh, please let me know how that turns out when you get your mounts replaced.
95pimpingcamry, alot of places ive searched have this as part of a 'kit.' It kinda sux how they would sell you something you don't need. i guess that's how commercials works as well
Old 11-13-2007, 09:56 AM   #9 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Yes..it is the strut mounts. I have the same problem in my rear right..and the rear left is starting to do it also.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
02 Tacoma strut replacement rubani 1st Generation (1995.5–2004) 9 06-29-2007 01:07 PM
94 Previa Strut Replacement? 94previa Previa Forum 7 03-11-2007 01:23 AM
struts abew330 Camry & Solara Lounge 2 02-14-2007 01:38 PM
AE92 strut mount replacement? aaron7 Archived Corolla threads 5 05-03-2006 01:15 PM
