Hub bushings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2007, 12:03 PM   #1 (permalink)
View doru's Photo Gallery
4th Generation Hub bushings
Hi all,
I'm looking to overhaul my rear hubs and brakes from drums to disks in my 97 Camry. I already changed the fronts to V6 brakes.
I got the parts from a junk yard and I'd like to bring them to best conditions before installing them in the car. I'm talking about the hubs, because the brake parts are new replacements, except for the calipers body.
The hubs have a pressed in rubber bushing for the suspension trailing arms. The rubber is in excellent condition. I'd like to powder coat the hubs for another 11 years or more of service. Problem is that powder coating requires oven time, and the rubber does not like it in the oven.
Getting a new bushing is not possible: dealer wants me to buy the entire hub. Going aftermarket I can only get poly bushings (Energy) but I'd like rubber.
Can the original bushing be repressed in after pressing it out? Has anyone tried it and can give some tips?
Should I just paint the hubs and forget about powder coating?
Thanks much!
doru is offline   Reply With Quote
Old 11-13-2007, 12:35 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
You might want to see if you can find some cheap bent up ones at a junk yard and practice on those before you start on yours. You might even try baking the beat up ones to see how the rubber responds to heat.
Kep
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
Pictures: Hub Centric Rings Installed for 2007 Camry LE I4 lammydi 5th & 6th Generation (2002-2006 & 2007-2011) 6 05-06-2007 10:19 PM
Steering knuckle and hub assembly abew330 Camry & Solara Lounge 0 02-07-2007 06:02 PM
Installed: SS Brass Cable Bushings & CC Short Shifter BLUEMEANIE 1st Generation (2005-2010) 2 07-09-2006 11:06 AM
Suspension slop and bushings BenG Hardcore Tech and Competition 14 08-29-2003 08:53 PM
