I believe that you are looking at the oil cooler. Check the online manual, page EG1-238 gives a general description and EG1-286 gives a repair procedure.
I am skeptical that this problem is related to your car not starting up. It's kind of like a radiator hose breaking. The car would run until the coolant ran out and the engine overheated and burned out the engine.
Kep
