Originally Posted by 93XLEcamry
this is off topic but was it hard to change your power window???...cus my regulator just broke and i wasnt sure if it was hard or not...how long did it take you to finish...and is there any special tools used?...again sorry sooooo off topic...just needed help
It was very easy. I have no mechanical ability and it only took about 30 minutes to replace the motor/regulator once I took the door apart. I was going to take step-by-step pics and post a DIY but my wife had our camera.
The only tools you'll need are a 10mm socket and a small standard screwdriver. I only used the screwdriver to help pry apart the wiring harness.
You'll remove four screws/nuts from the black horizontal brace, two nuts that attach the regulator to the door, two screws that attach the window to the regulator and three nuts that attach the motor to the brace. It's really just that simple. Now that I know what I'm doing, it would probably only take me 10 minutes or so to change it.
