Camry Ignition-Startup - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2007, 09:23 PM   #1 (permalink)
View camry1324's Photo Gallery
I have camry 98 86k miles done.For last couple of weeks i am facing following issue.
When i start the car, there is sound from front which stays for some time , then goes away.
This is same sound, which one experience on ignition.Typically this is for 1-2 sec, just when one starts the car(ignition).
Yesterday, when i got this sound, i tried to switch off the car, but even though i switch off the car and removed the keys, car/engine kept running.Only when this sound went off , i was able to switch off the car.
Can any body help me to identify the issue.
Thanks
camry1324 is offline   Reply With Quote
Old 11-14-2007, 02:03 AM   #2 (permalink)
Unco's Avatar
View Unco's Photo Gallery
Thanks
photobucket is your friend.
my suggestion: capture the problem with video and sound and someone might be able to help.
1977 P6 Ford LTD 351 Cleveland
Unco is offline   Reply With Quote
Old 11-14-2007, 09:59 AM   #3 (permalink)
View djb2's Photo Gallery
Was this sound the starter motor continuing to turn? As if the starter relay contacts stuck together, continuing to provide battery power to the starter motor?
djb2 is offline   Reply With Quote
Old 11-14-2007, 10:14 AM   #4 (permalink)
View wiccanferret's Photo Gallery
Take it to a parts store and have your starter tested. Sounds like it's sticking. Not an uncommon problem...sometimes it can be fixed by cleaning up the contacts on the outside, sometimes it has to be replaced.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
93 camry ignition problem joelmaup 3rd & 4th Generation (1992–1996 & 1997–2001) 10 11-13-2007 11:31 AM
1992 Camry LE stalled on startup, now won't start, no spark (continued) LineInTheWater 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-19-2007 08:40 PM
Getting alarm to chirp procedure - here it is JJMARINE 2nd Generation (2005+) 27 07-13-2007 04:06 PM
camry ignition igniter daza_mate Camry & Solara Lounge 6 04-14-2004 02:03 PM
