Well, before you go hypothesizing on what the problem may be, you should retrieve the code from the car to see what it is trying to tell you. Post your vehicle specifics, I'll see if there are provisions for doing it without a scanner. Also, you have six tubes going in and out of the unit, look on the back, you'll see three more.
Nevermind, I looked at your other posts. 00 LE V6....
You need to go under the hood and use a piece of wire (paper clip, etc..) to jump two terminals in the DLC connector. There is an extra step here depending on which ABC actuator you have. If your ABS unit says Denso on it(which is the one I think you have, with three tubes on top and three tubes on the back), you have to remove this shorting pin first:
If your ABS system is Bosch, then you can skip it and just go straight to jumping these two terminals (Tc and E1, diagram on the right):
When you have these two terminals connected, turn the ignition on and the ABS light should be blinking out a two digit number. Let us know what the number is, and I'll look the code up so you'll have some idea of where to go instead of guessing.
