I'm changing my valve cover gasket in a few days. I got the OEM gasket from the dealer and they told me not to use any sealant on it. Do I need to apply any sealant on the gasket before replacing the valve cover? If I do, what kind/brand of sealant and how should I apply it?
The whole back of the engine from just under the valve cover to just above the oil pan is wet from some mysterious engine oil leak. I'm guessing it's the valve cover hence the replacement. Is there any other seal or gasket that might be leaking back there? It most likely is a very small leak since I haven't noticed any oil stains on the driveway.
it might just be leaking from the valve cover.. get it cleaned off and drive it for a few days and check too see if there are anymore oil leaks.
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
The nuts around the spark plug holes are 30mm, correct? What's the torque specification for those? Also, what's the torque specification for the engine oil drain plug (on the oil pan)?
Get an in-lb torque wrench. Will come in VERY handy when dealing with nuts/bolts like these. I have both (well...actually have 3 torque wrenches) but if you get a in-lb wrench..set it to 204 and you will be golden.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
yeah, just replaced mine, with a non-oem valve gasket....literally did it 2 weeks ago, and it works like a charm...I used RTV sealant, as this was recommended by haynes...
LOTS OF GOOD 1MZ PERFORMANCE/STOCK STUFF FOR SALE! HERE!
You could also replace the distributor o-ring. It shrinks, hardens, and cracks over time which can allow oil to leak. I had to replace mine not to long ago due to a "mystery" leak. It wasn't the valve cover gasket. I traced it to the dist. o-ring. Once I replaced it, no more leak. Just a suggestion.
Did you apply the rtv all around the gasket or only on a few places?
Just the 'corners'.
Yeah...you may as well why you are there. The o-ring is really cheap and easy to change.
