lights problem!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2007, 04:14 PM   #1 (permalink)
Yeah, that's me
View Silent Shadow's Photo Gallery
3rd Generation lights problem!!!
i got a big problem. something happened to my dash and tail lights. both are out, but the brake lights work. headlights work fine, so i think it might be something with the wires. please help before i get pulled over. thanks.
Silent Shadow is offline   Reply With Quote
Old 11-15-2007, 05:36 PM   #2 (permalink)
Check 15A TAIL Fuse.
If TAIL Fuse is good ... then check Taillight Relay ... maybe replace with one from salvage yard to check out.
Location is J/B no. 1 ... under driver side dash next to kick panel on left.
Think it is behind coin box tray. ...
Just curious ... did anything unusual occur to knock out this fuse or relay?
Were you working on anything?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 11-15-2007, 06:29 PM   #3 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Sounds like you blew a fuse. Check the fuses. If they blow again you've got a short somewhere.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 11-15-2007, 11:13 PM   #4 (permalink)
Yeah, that's me
i checked all the fuses with a meter and the relays. nothing broken or blown.
Old 11-16-2007, 12:50 AM   #5 (permalink)
There should be two solid green wires coming out of J/B no. 1 ... Can you get a voltmeter, turn your light switch to on, and check to see if these green wires have 12V?
See p. 144 of the Gen 3 Wiring Diagram .... online repair manual for reference.
If you don't find 12V on the green wires ... check the green wire with red stripe, which controls the taillight relay activation coil, and should also have 12V.
Old 11-16-2007, 08:53 AM   #6 (permalink)
Yeah, that's me
alright. thanks. i will borrow my friend voltmeter and check tonight. what about the dash lights?
Old 11-16-2007, 10:13 AM   #7 (permalink)
Wiring Diagram shows that dash lights are included in one of the two solid green wires coming out of the J/B no. 1.
Old 11-16-2007, 02:58 PM   #8 (permalink)
Yeah, that's me
my bad. it was a fuse in the other fuse box. i got the spare and its all good now. thanks for your help.
Help with A Problem with my head lights... MellowToad 3rd & 4th Generation (1992–1996 & 1997–2001) 0 12-30-2006 12:03 AM
LED Map-Reading Lights DIY tonysun23 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-13-2006 08:05 AM
Problem with dash lights and DRL shadowninja General Discussion 7 04-30-2005 11:33 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
89 Camry problem: lights flicker when I brake ubongen 1st & 2nd Generation (1983–1986 & 1987-1991) 2 01-25-2004 04:35 PM
