TSB AX001-01 Trunk release - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2007, 06:27 PM   #1 (permalink)
View doru's Photo Gallery
4th Generation TSB AX001-01 Trunk release
Hi all,
I come accross this TSB about retrofiting an interior trunk release (escape).
The parts listed are:
[FONT='Arial','sans-serif']1 x – 64640–33030 Trunk Release[/font]
[FONT='Arial','sans-serif']4 x – 90464–00551 Clamp[/font]
[FONT='Arial','sans-serif']1 x – MDC 00107–00316–TR Installation Instructions[/font]
The dealer found the first one, but the rest are discontinued.
Does anyone has the instructions for installing this (last part above)?
Does anyone has an idea how the Clamp (sencond part above) looks like?
A long shot: does anyone knows where I can found the parts?
Thanks,
Doru
doru is offline   Reply With Quote
Old 11-16-2007, 06:04 AM   #2 (permalink)
Pissed
View Camryamnesty's Photo Gallery
I just looked it up, and if you buy the kit for it, it comes with instructions. There are no instructions from the toyota tech website
*EDIT*
I just saw that you said the other parts are discontinued, i think you best bet may be searching junk yards for one that has been done.
All these use the same parts.
Avalons 95-99
camrys 92-2000
Celica coupes 94-99
Corolla 93-2000
Echos 2000
MR2 90-95
Paseo 92-99
solara 99-2000
Tercel 91-99
The MR2 has a different trunk release
You need 4 clamps and the trunk release
Camryamnesty is offline   Reply With Quote
Old 11-16-2007, 02:41 PM   #3 (permalink)
More digging at the dealer and the clamps look like are not specific for the trunck release.
I remember that a clamp similar to that is used for securing the cranck position sensor harness to the timming belt cover on top of the 4cyl engine. This one is also discontinued. I replaced it with one piece of hose and 2 zip ties, one zip tie clamping the hose to the cover screw and the other holding the harness to the first tie. It works perfectelly under the hood and looks factory.
The one for the trunk release may actually be the same as the one for the harness.
Thanks for the info. It takes the worrying away by knowing that the handle comes with the instructions. If not I'll find a way of installing it. It can't be too hard. I was just hopping that the instructions come with a template for cutting the trunck lid linner, and spare me of trial and error fitting.
Handle should be here in 6 days.
List your Gen5 Problems mtnet2000 5th & 6th Generation (2002-2006 & 2007-2011) 61 10-15-2006 07:18 PM
Power trunk release WskyGrl Archived Corolla threads 7 10-28-2004 02:13 PM
Trunk Problem yrmac Camry & Solara Lounge 2 05-08-2003 02:42 PM
remote trunk release Dark Camry & Solara Lounge 8 05-28-2002 04:22 PM
