Do I need the actual headlight?..... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2007, 05:03 PM   #1 (permalink)
View tifosi2k2's Photo Gallery
Hello all ! I'm a fresh fish here, my first post!
My mother has a 1996 Camry. She has been complaining that her headlights need adjusted, and when I went to adjust them I found that the adjuster screws seem stripped out. So she took it to a body shop and they quoted her $300 per side She isn't a fan of putting that kind of $$$ into an 11 yr/old car, so, being the good son that I am, I offered to help.
Question is this: Do I need the headlight, or is there some sort of assembly that the headlight goes into that I need? And one more question: I read in the FAQ in the Camry section about how-to remove the headlights, it says it applies to the 92-94 models.. I assume the 96 isn't that much different?
Thanks!!
-chris
tifosi2k2 is offline   Reply With Quote
Old 11-16-2007, 05:29 PM   #2 (permalink)
View 94CoupeV6's Photo Gallery
I would just get all new aftermarket headlights for about $130. DEPO is the brand, and they are much clearer and look a lot better. Then aim away.
94CoupeV6 is offline   Reply With Quote
Old 11-16-2007, 05:46 PM   #3 (permalink)
Okay Thanks!
So the aiming mechanism is part of the headlight right?
Old 11-16-2007, 06:12 PM   #4 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
Depo actually doesnt make clear headlights for the 95/96 Camry, only the 92-94 (which are different in shape/size)
the adjustment screws on one of mine are stripped as well ... and the screws are attached to both the headlight and assembly (depending on left/right or up/down adjustment) if i do remember correctly
your best bet is to get a pair off of ebay like this
oh, and for headlight removal - the 92-94 should be similar to the 95-95, although the bolt positions will be slightly different due to different shapes in headlight/grille ... but its quite easy to remove, it took me about 15 minutes for one side
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 11-16-2007, 10:15 PM   #5 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
+1 OEM headlights for our cars are CHEAP on ebay!
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-17-2007, 09:09 AM   #6 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
As other said, Ebay. IF tyhe adjustment rod is still there, you can use pliers to turn it. It;s a pain, but it works.
Even a person thast does not know cars can change the headlight on the '96 Camry. It;s really straight forward.
5 Lug Corolla WHAT?
Old 11-17-2007, 09:37 AM   #7 (permalink)
Excellent! This place is great!
I guess I'll go the ebay route then.
I guess the thing that threw me off was the body shop insinuated that they had to remove the bumper and a bunch of other crap to get to the headlight assembly. I'm a VW owner and have never encountered such a thing when wrenching on those, but it being a Toyota, and my complete ignorance of these cars, I was a little worried. Sounds pretty straightforward.
Thanks everyone!
Old 11-17-2007, 05:45 PM   #8 (permalink)
1: To remove the headlight, unscrew the top 2 grill screws and remove.
2: Unscrew the 1 screw holding on the corner lens, rermove.
3: Unscrew 10mm nut attaching headlight to fender behind the corner light.
4: Unscrew the 3 10mm bolts (One on fender, 1 on bumper support, 1 right over that on the bracket).
5: Slowly pull light out, and then unhook the 2 bulb plugs.
And install n ew light.
5 Lug Corolla WHAT?
Old 11-17-2007, 05:57 PM   #9 (permalink)
My bad, didn't realize he was a 3.5
Old 11-18-2007, 08:22 AM   #10 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
i saw headlights on e-bay for $43 *(both sides)
deezeejoey is offline   Reply With Quote
DIY: taking apart headlights (56k: 20 low resolution pictures. you decide) JustAnotherAsian 5th & 6th Generation (2002-2006 & 2007-2011) 59 04-14-2010 05:14 PM
[UPDATED w/ more photos!!] Gen 3 new cystral headlight housing arrived (w/ pics) bowen 3rd & 4th Generation (1992–1996 & 1997–2001) 62 10-09-2006 11:01 PM
Tire suggestions? Vaipunk Archived Corolla threads 11 03-11-2005 06:48 AM
Seperating 02-04 Camry headlights italia490 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-17-2004 12:18 PM
my driver side headlight is really crooked TypeZer0 Camry & Solara Lounge 6 09-09-2003 09:15 AM
