Replace Fuel Filter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2007, 09:43 PM   #1 (permalink)
View Spartus's Photo Gallery
Hello,
I've been looking through the 98 Toyota Camry 4 cyl service manual and see no indication of when the fuel filter needs to be replaced? How often do you guys replace your fuel filter? I know most vehicles recommend 30k-60k intervals if the filter isn't inside the tank. Where is the filter located in the camry 4 cyl?...under the hood?
Thanks
1997 Toyota Avalon (No longer own)
Spartus is offline   Reply With Quote
Old 11-16-2007, 10:10 PM   #2 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Under the hood on the driver side strut tower.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 11-17-2007, 08:43 AM   #3 (permalink)
View digmycelica's Photo Gallery
Originally Posted by Spartus View Post
Hello,
Thanks
These were famous for the threads to become seized about halfway out on the bottom line. If you feel it getting real tight coming out then just screw it back in and take it to the dealer for replacement otherwise you will work hours and still may not get it installed or have a gas leak . you also need to use a 14 mm tubing wrench..
digmycelica is offline   Reply With Quote
Old 11-17-2007, 08:50 AM   #4 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $396985
View RningOnFumes's Photo Gallery
Do a search... there is a good thread lying around that is very helpful.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 11-17-2007, 11:42 AM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I've changed the fuel filter three times on a 1990 Camry with 350000 miles on it. Not once did the filter need to be changed but I figured that since I had it off, just put on a new one.
Kep
For Sale Brand New Camry Hybird for just $19000 cars01 Camry Hybrid 1 04-07-2007 06:00 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Fuel Filter Replacement xtremekuruption Camry & Solara Lounge 5 06-05-2005 09:35 PM
Fuel Filter Woes cosmicbutthairs Archived Corolla threads 3 06-08-2003 09:43 AM
