Looking for suggestions/input. It all started with the all-too-familiar 'klunk' I think we all know. Got me thinking about under my car. See my sig for my ride. I am assuming that 'klunk' is sway bushings/end links. Klunk showed up in the rear, and now I hear it in the front too. I'm at 137K and thinking it's time to spend a little time and money down there. Do the sway bushings/links, and then thought maybe it's time for struts all around too. Besides the 'klunk' I really dont have suspension issue.
Questions:
1. Struts. Replace just because it's time? I dont see leakage. What to use? Monroe gas? OEM? McAutoParts generic? Some performance aftermarket? I am not looking to hop this thing up or anything, and generally drive gently. I am fine with Camry's infamous soft ride. I look for value - quality, performance, longevity rather than wow factor.
2. Strut mounts. I see them for sale, I see people talking about replacing them. Replace 'just because' I'm doing the struts?
3. Sway stuff. This kit:
http://www.autozone.com/R,APP458995/...ductDetail.htm Is this a whole bushing/endlink kit? Are these better/worse than the standard rubber ones, those things are way cheap.
4. Sway link. Worth replacing?
5. Wheel bearings. Replace them since I have everything apart anyway? The other part of the puzzle is, I believe I have to replace my left side drive shaft as I have a vibration at highway speeds that wasnt resolved with re-balancing. The CV has a tiny bit of play on that side. So I will have that apart anyway. What do you guys get out of wheel bearings? What do you think of the vibration?
6. Do both drive shafts? One is going right behind the other?
7. Do some/all this and get a 4 wheel alignment?
I know that a whole bunch of questions, but I wanted them all in one thread as there is overlap with all these issues, rather than have a load of separate threads and trying to keep track. I bought this car in 2002 with about 40K on it. Before this I had a 89 Gen2 Camry and before that a 77 celica hatchback. All 5sp's. Looks like I get a new Toy every 10 years, Toyota has ahold of me. I appreciate all your input!
