Rear window regulator 94 wagon - help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2007, 01:12 PM   #1 (permalink)
View Robar's Photo Gallery
I found out the hard way that a sedan power window regulator does not fit in the wagon.
Does anyone know of a supplier / part number for a driver side rear door regulator for the 94 wagons? I have not seen any aftermarket listings calling out the wagon yet.............
TIA
Robar
Robar is offline   Reply With Quote
Old 11-18-2007, 02:09 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Page 945 of the parts list included with the online gen 3 manual. It shows (with the motor) part #: 69840-06030.
Kep
Old 11-18-2007, 03:17 PM   #3 (permalink)
Thanks - I did find one at NAPA online, and called the local store to check the application - say it is for the wagon, we'll see when I get it home.
Old 11-18-2007, 08:48 PM   #4 (permalink)
View unkit's Photo Gallery
Did all american variants come out with power windows? I'm having a few problems with manual windows - I.e. the regulator keeps dying on me.
ankit
unkit is offline   Reply With Quote
Old 11-21-2007, 08:58 PM   #5 (permalink)
No fit NAPA part
The damn NAPA part they said was for the wagon does not fit as well - its exactly the same as the other one I got. Need to do more homework on this and find the right one! I'll have to try and X reference the OEM one.....or just buy it.
Old 11-21-2007, 09:01 PM   #6 (permalink)
Toyota part #
The part number listed above is for the manual window regulator, not power, according to one of the Toyota dealers online parts store.
Old 11-22-2007, 08:46 AM   #7 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Your situation prompted me to poke around to see if something is available for our '93 wagon should the need arise. Found this on Ebay. Presented FWIW.
http://cgi.ebay.com/ebaymotors/TOYOT...QQcmdZViewItem
DFBonnett is offline   Reply With Quote
Old 11-22-2007, 11:58 PM   #8 (permalink)
Regulator infor
Thanks - I will contact the seller and see if they can convince me that it fits the wagon. Unfortunately, I have purchased 2 that were supposed to fit, but they do not. Both listings said they fit the wagon, and when I went back and checked they used the same part number for the sedan, which will not work. They are very similar, but the sedan model will not allow the door brace the motor mounts to to be bolted back in.
Old 11-23-2007, 07:46 AM   #9 (permalink)
'93 LE Wagon, V6
Please post back the results of your inquiry and and any specific vendor you locate. It will be very useful information to anyone with a wagon.
Old 11-24-2007, 01:33 AM   #10 (permalink)
Will do
I'll post anything I find out about the aftermarket units.
I just want to clarify that Toyota definitely has a separate part number for the wagon vs. the sedan regulators. I listed the numbers on another thread - don't have it handy at the moment.
Old 11-24-2007, 08:04 AM   #11 (permalink)
'93 LE Wagon, V6
[QUOTE=Robar;2064637]I just want to clarify that Toyota definitely has a separate part number for the wagon vs. the sedan regulators.QUOTE]
According to the Gen3 parts list pdf found here..
http://www.**********s.com/camry/ ...
the '92-'94 rear window regulators carry different part numbers for the sedan and wagon. Fronts are the same.
Old 11-24-2007, 09:31 PM   #12 (permalink)
Rear window regulators
Thanks - the thread is titled rear window regulator......figured that should clarify the application we are discussing.
Old 11-25-2007, 10:07 AM   #13 (permalink)
'93 LE Wagon, V6
Good luck to you.
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 05:51 AM
Tacoma with sliding Rear window... LinhDuyVo 2nd Generation (2005+) 2 02-08-2007 07:29 AM
01 Sequoia rear window problem MATHU1789 Sequoia Forum 2 11-21-2006 12:21 AM
1997 Rear Window Question humrz28 T-100 1 06-29-2005 12:52 PM
Drift Setting help for GT3 I hate Toyota Corp :( Off Topic 3 11-10-2003 10:36 PM
