Radiator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2007, 08:13 PM   #1 (permalink)
Mr.Nutcase's Avatar
View Mr.Nutcase's Photo Gallery
3rd Generation Radiator
There is a crack on top of the radiator, Can this be fixed? Is the radiator made of plastic? Where would you recommend a radiator? from junkyard, autostore,dealer? How hard is to remove it, What type of coolent does it use? It is not the green one, it is redish/orange.
ECT,EGR,TPS,MAF,CMP,CKP,02,
Mr.Nutcase is offline   Reply With Quote
Old 11-18-2007, 08:22 PM   #2 (permalink)
View eilros's Photo Gallery
I had the same thing happen to my radiator. I was able to patch it with QuikSteel until I could get it replaced. I just took it to my Toyota dealer and replaced it for $265 (aftermarket radiator).
If you do a search you should be able to find some good DIY info. It seems like a pretty easy job if you have the time and a little mechanical ability. You should be able to get a radiator on eBay for less than $100.
Cracked Radiator
eilros is offline   Reply With Quote
Old 11-18-2007, 08:28 PM   #3 (permalink)
Mr.Nutcase's Avatar
Sounds easy, I haved done other things in cars, such as spark plugs, oil pan gasket replacement, transaxle seals
Old 11-18-2007, 08:40 PM   #4 (permalink)
View ToyotaJohn's Photo Gallery
New Radiator
Try www.completeradiators.com you can get a radiator a whole lot less than $260 bucks. Also, they're Modine with a lifetime warranty.
John
ToyotaJohn is offline   Reply With Quote
Old 11-19-2007, 12:53 AM   #5 (permalink)
Defender of the Universe
View Miranthis's Photo Gallery
I replaced the radiator in my 98 last december and it was like $119. I did the labor and even reused the drained coolant. It is way easy to DIY as the manual is on line on this site. There is little reason NOT to do this yourself. There are two big hoses, a pair of AT trannt cooler lines and then the mounting hardware (probably 2 - 4 bolts IIRC)
Also, call the local radiator shops and they should be able to get you an after market one with a good warranty that is brand new.
Jeff
Miranthis is offline   Reply With Quote
Old 11-19-2007, 02:19 AM   #6 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
I took mine to an aftermarket rad shop which pulled, cleaned, replaced the top and reinstalled for under $200. Put another 100K on it since then.
Dave's is offline   Reply With Quote
Old 11-19-2007, 02:23 AM   #7 (permalink)
View wahed3001's Photo Gallery
Try the seller 'Radiator Doctor' on eBay. Good quality US made radiators with lifetime warranty for less than $100 shipped. There are ton's of other sellers on eBay selling similar products. Shop around!
wahed3001 is offline   Reply With Quote
Old 11-19-2007, 03:49 AM   #8 (permalink)
View 94CoupeV6's Photo Gallery
http://cgi.ebay.com/ebaymotors/Toyot...spagenameZWDVW
94CoupeV6 is offline   Reply With Quote
Old 11-19-2007, 06:36 AM   #9 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The replacement is pretty easy to do yourself. I would highly recomend getting one of the all metal aftermarket replacement radiators on the market.
Kep
Old 11-19-2007, 10:55 AM   #10 (permalink)
Mr.Nutcase's Avatar
Thanks, on thursday I will replace the radiator. Should I replace the radiator hoses?
Old 11-19-2007, 11:28 AM   #11 (permalink)
Never a bad idea to change the hoses while you are at it. It may not be necessary though if yours are firm and have no cracks.
Old 11-21-2007, 10:43 AM   #12 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
I just did mine. Check: theradiatorconnection on ebay! Great price good fit, aftermarket. Easy DIY. Check posts.
04 SC430 05 RX330
96 Camry LE T-boned Oct. 09 RIP
mandyfig is offline   Reply With Quote
Old 11-22-2007, 11:07 AM   #13 (permalink)
Mr.Nutcase's Avatar
THANK ALL!, I will fixed it soon, I will installed a radiator from local store for 100 dollars,
Old 11-22-2007, 11:21 AM   #14 (permalink)
1999 camry 4 banger
View matt9112's Photo Gallery
anyoine here got the radiator support *intire piece*
1999 camry 2.2
custom painted interior
custom cold air intake
matt9112 is offline   Reply With Quote
Old 11-22-2007, 12:30 PM   #15 (permalink)
Mr.Nutcase's Avatar
I was wondering what type of coolent should I use?
Gen 3 I4 Radiator Change/ Thermostat Change RningOnFumes 3rd & 4th Generation (1992–1996 & 1997–2001) 54 10-22-2011 02:35 PM
91 Camry Radiator Question champ_168 1st & 2nd Generation (1983–1986 & 1987-1991) 2 08-15-2005 01:37 AM
Replaced Radiator - what is this wire?! PDXterra Celica Forum 8 08-13-2005 07:43 PM
Gen 3 Radiator install *DIY* Camry_rider 3rd & 4th Generation (1992–1996 & 1997–2001) 0 07-08-2004 01:53 AM
So I'm going to finally replace my radiator...and I need some help- A Bit Urgent! Structureboy Camry & Solara Lounge 10 04-18-2004 12:31 AM
