Gas Pedal Sticking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2007, 10:54 AM   #1 (permalink)
hav
View hav's Photo Gallery
4th Generation Gas Pedal Sticking
Hi Guys,
When I press gas it seems to stick. I had my throttle body serviced so it's not the plate....Can the pedal wire stick in the casing? Will WD 40 help. Where do I spray it?
I have a 99 Camry V6.
Thanks
hav is offline   Reply With Quote
Old 11-19-2007, 12:17 PM   #2 (permalink)
ELL
ELL's Avatar
View ELL's Photo Gallery
I too have a similar problem, and would like to seek a possible solution
mine only occurs sometimes. like when i'm at a red light
and i'll apply pressure to the pedal, it won't move until I overcome it with more pressure.
2000 Camry LE I4.
ELL is offline   Reply With Quote
Old 11-19-2007, 12:31 PM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
try unhooking the throttle cable from the throttle body to narrow down where the sticking is coming from. if its not the throttle body in hav's case, shoot some graphite spray where the cable goes into the sheathing at both ends (by the throttle body and by the gas pedal). also spray the pivot points on the accelerator pedal as well. graphite spray will work well because it doesnt get sticky so it wont trap dirt.
Old 11-19-2007, 12:46 PM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
There is a throttle plate return spring on the front side, put a rag below it and spray some degreaser / parts cleaner on that if it is really dirty. If it is still warm, use soap type cleaner and rinse with water.
Remember to use dry lubricants, like graphite spray or dry teflon spray, silicone sprays and spray lubes made with teflon will collect alot of dirt into the cable casing. If I recall, there is a rubber boot (bellows) at the cable casing end before a bare cable sticks out. Is it still there in good condition?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 11-19-2007, 01:00 PM   #5 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906927
iTrader Score: 59 reviews
Maybe the TB wasn't cleaned very well!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 11-19-2007, 07:02 PM   #6 (permalink)
Gameroom cash: $303055
I have to agree with eyeball96. I would thoroughly clean the throttle body again yourself. Pay particular attention to the backside of the throttle plate inside the throttle body, and where the throttle plate seats inside the throttle body when you are off the gas. That's where it usually sticks. Do a search on this forum for "throttle body cleaning". There are some good articles on it and a great do-it-yourself tutorial with pictures.
Mike
Old 11-19-2007, 07:40 PM   #7 (permalink)
Gameroom cash: $924000
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Eye8Pussies Solara was the same. We cleaned the TB and issue was gone.
5 Lug Corolla WHAT?
Old 11-19-2007, 07:59 PM   #8 (permalink)
1999 camry 4 banger
View matt9112's Photo Gallery
same with a I4 i have same problem
1999 camry 2.2
custom painted interior
custom cold air intake
matt9112 is offline   Reply With Quote
Old 11-27-2007, 11:10 AM   #9 (permalink)
View sdpages's Photo Gallery
Toyota camry solara 2000 gas pedal sticking
I'd having this problem for some weeks. The gas pedal sticks when picking up after stopping at a red light. Also sometimes even while driving in highway i could feel the gas pedal sticking. Untill yesterday i did oil change and tire rotation at Sears. but I also did this "Fuel System Cleaning" $69.99 I thought it would prevent any problems for winter. And guess what? my gas pedal sticking problem was completely gone. So then i knew that it has to do something with the fuel system cleaning. I'm not a pro in cars so i dunno what they did in fuel sys tem cleaning but some procedures in FSCleaning did the magic. It has been really irritating me but now I'm Happy.
sdpages is offline   Reply With Quote
Old 11-28-2007, 10:17 AM   #10 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
I had that problem before, and took it to the dealership. I got an fuel induction service. Now it turned out pretty good.
1992 Toyota Camry LE ; 4 Cylinder ; Pioneer DEH-P7800MP
Pioneer Premier TS-A641P 4-way 6 1/2 ; Pioneer TS-A6991R 5-way 6x9 ; Cerwin Vega EXL Series 1200D Amp ; Cerwin Vega V-Max 12.2 Dual Subs @ very hot 1 Ohm
Hey! It ain't much to beat the block down, but it'll work for now...
JayMax03 is offline   Reply With Quote
Old 11-28-2007, 04:32 PM   #11 (permalink)
toyota = cool
tacomonkey69's Avatar
View tacomonkey69's Photo Gallery
4th Generation
the same thing is happening to me but it's my clutch pedal that is sticking. what should i do?
tacomonkey69 is offline   Reply With Quote
stiff gas pedal.. 9MOON MR2 Forum 4 01-13-2007 04:52 PM
accelerator pedal sticking IncredibleLE Camry & Solara Lounge 8 09-19-2005 12:40 PM
3.5 Gas Pedal gets stuck RningOnFumes Camry & Solara Lounge 25 08-01-2005 01:22 AM
Noise when I step on or let off the gas pedal BDSL MR2 Forum 13 12-04-2003 01:20 PM
