This is from a 1996 Camry, but should be the same, are very close, to most others.
Dave (Rininonfumes) reminded me that I should add to take off the Master Cylinder cap when pushing the piston's back into the calipers just for ease.
Originally Posted by Novice_cardude
Should also get some high temp grease (NOT anti-seize) and lube the slide pins ... if nothing else. It's also a good idea to take the torque bar and rotors off and have them machined at a shop to get rid of the old friction material buildup, or any thickness variation.
1: Jack up the car and remove wheel. Place Jack Stand under car for safety.
2: Unscrew the bottom slide pin caliper screw as shown:
3: Pull up the caliper. It may be a little tight, but just wiggle it a little and it will slide off. It's best to tie the caliper up EVEN if it looks like it will stay. Just a precaution to make it easier.
4: Take note at which way everything is together. Circled in red is the ware indicator for when the pads get low. Put it back in the same place on the new pads. There should be a little notch that it clips into.
5: Push back the piston to allow for the new thickness of the pads. Shown is the easiest tool to use for this. You can get them cheap.
6: Put the backing plate(s) and ware indicator back onto the new pad. Yous may differ slightly.
7: Pop the Pads back in just how you took them out.
8: Put back the springs that push the pads apart. If your car has over 60k miles, I'd suggest getting new ones from the dealer. They are cheap. Mine after 85k miles lost a lot of their spring.
9: Pull the caliper back down, and tighten the slide pin caliper screw.
10: The brake peddle will go to the floor when pumping until they readjust to the new calipers. So pump the brakes until hard BEFORE you start driving.
