Middle Camry logo peice rattling when subs hit. help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-20-2007, 07:56 AM   #1 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
3rd Generation Middle Camry logo peice rattling when subs hit. help!
ok guys so i just got new subs in my car and i need some help. i know every trunk will rattle a lil when the bass hits. but mine is bad. ive figured out that the middle peice that says camry on it inbetween the 2 taillights is really really loose and rattles bad! and it stops rattling when i press on it in certain areas or pull a lil. any ideas what i can put behind it or how to get it off and fix it? or why it is loose? help is greatly needed! i have a 95 camry
Chris
Spitfire is offline   Reply With Quote
Old 11-20-2007, 08:46 AM   #2 (permalink)
'95 Camry V6 XLE
View eddie926's Photo Gallery
It's held on by some bolts that go through the trunk lid. If you peel the carpeting back on the lid, you should be able to see them and see if they need to be snugged up. I'd be careful about over tightening them though as you might damage the panel.
If you can't get it to stop rattling you might look into putting some dynamat or something like that between the panel and the trunk lid.
eddie926 is offline   Reply With Quote
Old 11-20-2007, 09:49 AM   #3 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
ive had teh same problem, u haeve to cram some thin pieces of foam or other insulating material up underneith it or remove the pannel then put foam under it. i actually placed pieces of cardboard under there for a while and it worked great.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 11-20-2007, 10:01 AM   #4 (permalink)
JDM Inspired
Spitfire's Avatar
3rd Generation
hmmm ok well im at school :p and my lunch break is comming up at 11:20 till 12:05 think i could do it in that amount of time? its 10:58 right now.. i think what imma do is see if my pre-engineering teacher has any cardboard but do u think i can get it all fixed in that amount of time? :P what kinda tool do i need to get the bolts off cause it looks like theres a long rod inbetween the bolt and the mettal thats in the way of that lil hole.... hmmm how did u do it bigbird? i think imma give it a shot :p and what i dont finish ill do after school or sumthin :P how did u go about takin it off? if u get this before 11:20 type back how u get it all off and done and where to put the cardboard at to fix it?
thanks
chris
Old 11-20-2007, 11:35 AM   #5 (permalink)
Newbie
deezeejoey's Avatar
View deezeejoey's Photo Gallery
also check ur license plate. they rattle a lot from the base too.
deezeejoey is offline   Reply With Quote
Old 11-27-2007, 09:46 AM   #6 (permalink)
JDM Inspired
Spitfire's Avatar
3rd Generation Thanks!
Thanks bigbird! i spent about an hr the other day took out the intire center peice and opened it up and laid strofoam in all the gaps and pressed it all back in and bolted and screwed it all up! it wont rattle now if my life depended on it! it sounds great! and the only thing that i get a little rattle now is from the center deck that hold the 2 6X9s any ideas for that bigbird?
Old 11-27-2007, 01:16 PM   #7 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
i put foam strip around the 3rd braking light cover. looks hella funky but it gets the job done. and i also put some foam stripping behind the license plate. but if you have the plate frame on it, it'll still rattle.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 11-27-2007, 01:55 PM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
i prety much did the same thing, weather strippin or some other insulating substance. i ended up just gettin the stripping and wedged it all the way around the underneith of brake light cover. teh preasure pushed it agains the window enough so it wouldnt rattle and i didnt have weather stripping visible around the light. but putting it between the cover and the window would work well too, prolly better.
if its commin from the pad that covers the rear deck then just find the loose contact points and some double sided foam tape or even the soft side of velcro tape(what i used) and that will reduce it well.
R.I.P.
Car Domain:
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
My Camry was 'hit & run' kippy Camry & Solara Lounge 12 02-17-2004 04:31 PM
Rattling noises in camry Ken4 Camry & Solara Lounge 1 01-29-2003 02:04 AM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
